586,089 active members*
3,846 visitors online*
IndustryArena Forum > CAD Software > Autodesk > write protected
Results 1 to 6 of 6
    Sep 2003
    174
    write protected
    Hi Guys,
    I'm using Autocad 2000 Li and I've just had to do a complete re-install on the PC because of a very bad virus. Before doing this I saved all my work by burning it onto a CD from my documents which is where I save all my drawings as well as letters, invoices etc.
    When I came to put them back into my documents off the CD they were all "read only" drawings. Also If I do any work on these drawings and try to save it they are all "write protected".
    How can I resolve this. There is about five years work in this little lot and I don't want to loose it all.
    Steve.
    Mar 2004
    120
    Hi Steve,
    I don't know about windoze XP but previous versions allowed you to change the properties of files by right clicking the file name and clicking properties. Next choose the desired attributes by clicking or unclicking the checkboxes.
    HTH regards Gary
    ps I think that in XP you have to have administrative rights
    embrace enthusiasm to accomplish the task
    Gary Davies... www.durhamrobotics.com
    Mar 2004
    37
    CD's are readonly devices so the file attribute was changed to Read only when they were written to the CD. It can be changed back easily.
    One file at a time method: (assuming you are right handed, and all the files are copied back onto the harddrive.)
    Using your mouse left click on the file you want to change from read only. Only click once. The filename will be highlighted and turn blue. Now press the right mouse button, a toolbox will show up. At the bottom of the box find the text Properties. Left click on Properties. Another new toolbox will pop up. You will notice that at the bottom of this toolbox a little check box call Read Only is checked. Left click to turn the Read Only attribute off. Close the toolbox and this file has can be Read and Written as normal.
    You can do multiple files at a time by Left clicking on the first file, then press and hold down the Ctrl key on your keyboard and Left click on the other files you want to include. Once all the files have been selected, do a right click of the mouse, Properties, etc.
    Cheers
    May 2004
    14
    Another way around this would be to save the file to the hard drive with a slightly different name using
    "saveas". For example: drawing1.dwg (write protected) becomes drawing2.dwg
    Brian
    If all the files are in one directory, open a DOS window (command prompt), go to the directory the drawings (or any other files) are in and type:
    attrib -R *.*
    Sep 2003
    174
    Hi Guys,
    I managed to sort it out in the end. Just changed the attributes by unchecking the read only box so thanks for the help. I could do all of the files at the same time by selecting them all together then going properties etc. Everything is now back to normal so I'm happy again.
    All I need to do now is find the mo'fo' who created the virus in the first place and my life will be complete. Don't suppose any of you can help with this one.
    Many thanks,
    Steve.
  1. someone wanna write a program?
    By ljoe1969 in forum DIY CNC Router Table Machines
    Last Post: 06-07-2004, 01:47 AM
