Hi Guys
Basically, milling a rectangle (test) 1mm deep (so basically 2 cuts) (250mmX145mm) at 0.5mm increments using dynamic contour milling in 2D.
This should be a short straight forward G code program but when I generate the G code its thousands of lines of code and each axis traveling in a straight-line X and Y shows coordinates traveling 0.1mm at a time each line of code. (Explains why the G code is so long).
Just wondering what I'm doing wrong, is there a setting or am I just using the wrong milling function i.e. not dynamic contour milling???
Thanks guys.
Bart
