586,110 active members*
3,162 visitors online*
Results 1 to 6 of 6
    Jan 2017
    6
    DM3000 Z travel distance?
    Can anyone confirms me DM3000 Z travel disltance, is it 11inch?
    THX,
    Aug 2008
    406
    Re: DM3000 Z travel distance?
    With or with out tailstock ? What type of chuck , center, collet chuck are you going to use ?
    Jan 2017
    6
    Hi Gabedrummin,
    Below is my DM3000, it would be great to know both the distances with Tailstock and without.
    Can those information be found in the Dynamyte 3000 Manual 1 and 2 or Service manual?
    Aug 2008
    406
    It will travel to the right until the carriage hit's the limit on the back side of the bed . It will travel z- till it crashes into the chuck if you don't stop it . So the limit switch on the back is adjustable so you can adjust the home position .The length of z travel is between those two points.
    Aug 2008
    406
    MY machine has about 8 inches of z with the tail stock on and about 12 with it off .
    Jan 2017
    6
    Quote Originally Posted by gabedrummin View Post
    Thanks Gabedrummin!!
  1. Z axis travel distance?
    By NogginBoink in forum Open Source CNC Machine Designs
    Last Post: 11-11-2013, 05:38 AM
  2. Question on Travel Distance
    By yury89 in forum DIY CNC Router Table Machines
    Last Post: 01-26-2011, 09:02 AM
  3. Mach 3 travel distance
    By Bell 430 in forum Mach Software (ArtSoft software)
    Last Post: 11-09-2009, 06:16 PM
  4. distance z axis can travel
    By mostlund in forum DIY CNC Router Table Machines
    Last Post: 12-15-2008, 05:04 AM
  5. Travel distance is inaccurate.
    By thuffner3 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-15-2004, 03:32 PM
