586,110 active members*
3,247 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > NEED HELP: Haas ST-10 turret problems
    Feb 2023
    Exclamation NEED HELP: Haas ST-10 turret problems
    Hi All,
    I am at an impasse and ready to call service. Not sure if they will help me over the phone and wondering if anyone has experienced this scenario.
    I had a student rotate the turret with a boring bar hanging too far out the backside and struck the base while tool changing. This sent us into clamping alarms 125? 113? I was about half a hole off on the coolent nozzle. Turret would rotate but not clamp obviously. I looked up the coupling realignment procedure and proceded to strip the covers. We couldn't get past the M43 (unclamp) because of error messages about clamping. Long time later I was able to retract the turret and got it to unclamp. I was then able to rotate the coupling and realign the coolant hole. I finished the procedure and rehomed the machine with startup.
    When the turret reaches the startup home location, unclamps to rotate I get a 113 alarm (failure to reach unclamp switches)Additionally, with a message that says "NO ZERO A" once I clear that alarm. Is this because of the switch or a parameters thing with misalignment of the A....I am assuming the A is the turret rotational axis? I do not have an A axis. Only two are available to activate, obviously X and Z.
    Can someone help me solve this. Is it a matter of clamp sensor adjustment. I jusyt don't want to keep deepening the rabbit hole and get screwed up worse.
    Thanks in advance.
    Jan 2013
    474
    Quote Originally Posted by Doberman44 View Post
    Hi All,
    Thanks in advance.
    At X0 can you sweep the turret bore or a ground tool holder diameter from the spindle?
    The indicator should show zero zero in the X plane and zero 90deg to it.
    If not, you haven't fine adjusted the turret position.
