Hello, and thanks for taking the time to read this. I have a carvin guitar, which has a bolt on neck that has the same dimensions as a feder strat neck at the bolt. However, the rest of the neck is slightly different and a bit wider then a standerd fender neck. Is it possible to recarve the neck to a standerd fender size? And if so is that a job a novice can do? And if so how?
Thanks sooo much,
Solomon
