586,104 active members*
3,252 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Help please needed CNCEST 3040 Power Supply
Results 1 to 9 of 9
    Sep 2016
    29
    Hi and thanks in advance.
    I badly need help in tracking down a controller for the 3040 CNCEST 3 axis router machine.
    Mine has suddenly developed a strange fault: 3to4 minutes after starting its run the operation stops. The power that drives the machine goes off, but not totally, the spindle keeps running.
    Best regards,
    Joe
    Apr 2022
    135
    Re: Help please needed CNCEST 3040 Power Supply
    Isn’t it just generic power supply? It might go to thermal overload but spindle relay on a different power?
    I have one of Chinese boards that gets power from USB and that keeps spindle relay on even the main power supply is off.
    Sep 2016
    29
    Hi, thanks for the reply, but I have no idea how to solve this problem other than just replacing the whole controller.
    I would have thought that it would be quite easy to just source another one, but obviously not,
    Are they quite straight forward to build from scratch?
    Best regards
    Apr 2004
    5737
    It might not be the controller. Are you using Mach3 with that, and trying to run a 3D toolpath? The version supplied with Chinese machines is unlicensed, and after 500 lines of code it will suddenly quit. Since the M05 code hasn't been issued, the spindle will keep running. If this is the case, the solution is to purchase a license for Mach3, or substitute another program like LinuxCNC which doesn't require one.
    Andrew Werby
    Website
    Sep 2016
    29
    Hi aweby, thanks for the reply but it is a genuine copy of Mach3 and registered to me.
    I just feel there must be a way to source the correct controller box and power supply.
    Best regards
    Apr 2004
    5737
    These machines are known for their shoddy electronics. If you're ready to give up on them, I've had good luck with the G540 from Geckodrives, along with a 48v 10A toroidal power supply from Antek and a UC100 motion control card (aka adapter) from CNC4PC.
    Andrew Werby
    Website
    Sep 2016
    29
    Many thanks for your help on this, it is certainly an option I shall explore.
    Best regards
    Apr 2022
    135
    It is not difficult to track the problem. But you have to provide more information and photos - controllers, drivers etc.
    Sep 2016
    29
    Ok, thanks Vlod, I will put together a few photos and enclose them with my next post.
    Best regards
  1. CNC 3040 - Power supply and Spindle problem
    By Hawaiicnc in forum Chinese Machines
    Last Post: 01-24-2016, 06:07 AM
  2. New member - Need some advice on a power supply for a ebay 3040 machine
    By Mudslingerdude in forum European Club House
    Last Post: 04-07-2014, 04:49 AM
  3. Power Supply advice needed
    By Raf-1200 in forum Australia, New Zealand Club House
    Last Post: 10-15-2013, 08:24 PM
  4. Information needed on new power supply
    By IBBruin in forum Automation Technology Products
    Last Post: 02-23-2012, 01:20 AM
  5. power supply needed.... please help
    By goneflyin in forum CNC Machine Related Electronics
    Last Post: 01-09-2010, 05:49 PM
