586,106 active members*
3,167 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > I have a huanyang hy02d211b VFD . 110 VAC water cooled spindle
Page 2 of 3 123
Results 21 to 40 of 42
  1. #21
    15362
    Re: I have a huanyang hy02d211b VFD . 110 VAC water cooled spindle
    Quote Originally Posted by mpresti8 View Post
    I am running from the VFD not the computer or Mach 3
    Honestly this thing is driving me nuts.. One thing that I have seen on these YouTube videos is that when they change a value and press set the screen displays END mine does not display that
    Sometimes they don't display End, but go back and check the Parameter to see if it has set to what you have input, you may have to do a Full Drive Reset and then install all the Parameters again I will give you a full set to install.
    I just saw you spindle is water cooled spindle, so why are you using 133.33 as a minimum speed setting, 100 to 120 is the norm for any water cooled spindle.
    Mactec54
  2. #22
    May 2016
    27
    I have been trying to get my VFD up and running properly for several weeks. Thanks to automationtechinc I can now operate the spindle at any speed. This guy is absolutely amazing. The knowledge he possesses is very impressive. I will definitely going forward purchase the components that I need from him. John Thank you so much
  3. #23
    May 2016
    27
    Thank you for all of your help. Seems to be working fine now. Obviously I had some settings messed up. John went through them with me.
  4. #24
    May 2016
    27
  5. #25
    15362
    That is what I said in the Posts, it should only take 5/10min to Program one of these VFD drives.
    You should share / post what you were doing wrong so it can help others, John uses my Parameter list. it is what they have on their web site.
    Mactec54
  6. #26
    May 2016
    27
    I will send out a copy of what was programed.
  7. #27
    May 2016
    27
    Quote Originally Posted by automationtechinc View Post
    Give me a call, I will help you to check to find the problem
    The phone number is on our website:
    https://www.automationtechnologiesin...ucts-page/vfds
    Here are the settings that work
    PD00=0
    PD001=0
    PD002=0
    PD003=230
    PD005=400
    PD004=400
    PD006=2.5
    PD007=.0.20
    PD009=15
    PD010=8
    PD011=120
    PD013=8 FACTORY RESET
    PD014=10
    PD015=112
    PD025=1
    PD027=0.80
    PD141=120
    PD142=5
    PD143=2
    PD144=2600
  8. #28
    15362
    PD00=0
    PD001=0
    PD002=0
    PD003=230
    PD005=400
    PD004=400
    PD006=2.5
    PD007=.0.20
    PD009=15
    PD010=8
    PD011=120
    PD014=10
    PD015=112
    PD025=1
    PD027=0.80
    PD141=120
    PD142=5
    PD143=2
    PD144=2600
    PD003=230 this is what the KeyPad uses for the spindle speed, having it at 230 will only give you just over half max RPM from the Keypad.
    PD015=112 Deceleration This is ridiculous, this is giving the spindle 112 seconds to stop most use 3 to 8 seconds
    PD144=3000 this needs to be 3000 this unlocks the Drive to give you max RPM of 24,000 RPM
    I guess you did a Reset because there is nothing special about these settings, I'm sure if this is working correctly, you are going to have some trouble down the road, you sure you have a genuine HY VFD Drive
    John should be not giving people these numbers as they are incorrect
    Mactec54
  9. #29
    15362
    some how there was a double post
    Mactec54
  10. #30
    15362
    Here are the correct set of Parameters you should be using for your Spindle.
    Huanyang Mactec54 Note ™
    1.5Kw110v / 120v 400Hz Water Cooled
    PD000=0 ( 1 For Parameter Lock )
    PD001=0 (1 For Remote Control)
    PD002=0 ( 1 For 0-10v Terminal Control or Remote Trim Pot Control )
    ( J1 Also Needs to be set for Remote Terminal Control 1-2 jumper connection )
    PD003=400
    PD004=400
    PD005=400
    PD006=260
    PD007=20
    PD008=120 ( 110v Motor Rated Voltage Max 120v )
    PD009=78
    PD010=6
    PD011=120
    PD013= 08 is for Factory reset, Only use this to set VFD to Factory Default Settings
    PD014 Acceleration=8 ( Adjust to suit)
    PD015 Deceleration=8 (Adjust to suit)
    PD023=0 ( Forward Run Only )
    PD041=8 ( Carrier Frequency up to 10 Max for these Spindle motors)
    PD120=100 ( Stall Prevention )
    PD141=120 ( 110v Motor Rated Voltage Max 120v )
    PD142=7 ( 7A Motor Max Amps 1.5Kw )
    PD143=2 ( Motor Number of Poles)
    PD144=3000 (Max Motor RPM) 3,000= (24,000)
    PD070=0 ( This may need to be set to 1 if Control Voltage is 0-5v or for Pot use )
    PD072=400
    PD073=120
    PD174= ?? ( To Be Set to the VFD Drives Max Rated Output Amps )
    Mactec54
  11. #31
    I think there are some type errors.
    PD003=230 should be 400
    PD015=12
    PD144 can be 3000 (Max 24000 rpm), If you use PD 144 = 2600, your max speed will be less than 24000 rpm
    We sold many VFDs and We helped many people to set up
    https://www.automationtechnologiesin.../vfds/kl-vfd22
    I helped many hobby for free, I did not never give any one incorrect information
  12. #32
    15362
    PD015=12
    I'm not sure who got it wrong but there are a lot of incorrect Parameters in what he listed.
    PD144 should never be 2600 if you have a 24000 RPM spindle, this is part of setting the motor name plate Parameters.
    PD144=2600 is incorrect information for his spindle
    Mactec54
  13. #33
    May 2016
    27
    The settings that I posted contained some typos. Please forgive me. I cannot thank you enough for the time you spent on the phone helping me out. I am new to these types of equipment and because of your help it is working fine now
  14. #34
    May 2016
    27
    Mactec54 thank you for your help as well. JOHN did not give me incorrect information .I made the mistake of typing the settings in incorrectly. I do not think it is your place to chastise John for helping me. I made the mistake not him and you probably should apologize to him. Everyone here is trying to help each other not belittle one another
    Mike
  15. #35
    May 2016
    27
    John thank you so much for your help. I made some typos telling everyone what settings that I used. Sorry for any confusion. Thanks to you helping me my machine is running like new.
  16. #36
    15362
    Mike
    There is not a problem with John as he is using my Parameters any way and they are listed on their web site, but he did make a mistake in his reply post.
    This is not correct, and he did not make any typos, this kind of posting is only confusing for others that may read these posts.
    Mactec54
  17. #37
    May 2016
    27
    John did not make the mistake I did. So lets let it be. Thank you again
  18. #38
    15362
    Read and understand what he posted; this was nothing to do with what you posted! which had many incorrect settings.
    John Posted this by himself, which is incorrect and a lack of understanding of what these Parameters are for.
    This is incorrect information to be posted.
    Mactec54
  19. #39
    May 2016
    27
    Obviously you have an issue with john, who by the way took the time to help me get this VFD running correctly. John explained the settings to me rather than telling me to change this or change that. For that I am grateful. You requested that I post the settings. Had I known that your reason was so that you could try to pick John apart I would not have posted them! My machine is running so why don’t you Give it a rest and get off of Johns back.
  20. #40
    15362
    No, I wanted to see what got you going, because this is helpful for others, you have a very twisted mind set to think it was for any other reason
    You ended up with all the same Parameters as what you had before, so we still don't know for sure what you had wrong.
    I Have No issue with John as I have already said, they have and use my Parameter lists on their web site.
    Mactec54
Page 2 of 3 123
