586,062 active members*
4,488 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > For Sale Only > Precision Matthews PM-940 CNC Conversion Parts
Results 1 to 3 of 3
    Sep 2014
    21
    I was planning to convert a PM-940V to CNC but plans have changed. Now up for grabs is a Arizona CNC Kits heavy duty PM-940 ball-screw conversion with 1/2" shaft stepper/servo mounts. $1000 for everything that was included in the kit. Also have the following clearpath parts from Teknic, $3000 for this package OBO. Was planning to go 4-axis with this but can lower the price for only 3 motors. Also have a few odds and ends like enclosure box and controller, etc. PM for more details. Everything is brand new, not even opened from the original shipping boxes.
    AC Power Cable for IPC-3 and IPC-5 IPC35-CABLE110 2
    350/500 Watt DC Power Supply IPC-5 2
    ClearLink Ethernet/IP Controller CLNK-4-13 1
    DC Power Cable, IPC (or hub) to ClearPath, 10 ft CPM-CABLE-PWR-MS120 4
    Controller Cable, 10 ft CPM-CABLE-CTRL-MU120 4
    ClearPath Integrated Servo Motor CPM-SDHP-3421S-ELS 2
    ClearPath Integrated Servo Motor CPM-SDHP-3436D-ELS 1
    ClearPath Integrated Servo Motor CPM-SDHP-3446P-ELS 1
    DC Power Distribution Hub POWER4-HUB 1
    Terminal Block Plugs, 3-position (pack of 10) CC-3TERM-PLUG-10PC 1
    Re: Precision Matthews PM-940 CNC Conversion Parts
    The CNC kit price seems very good.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Apr 2018
    47
    Hi Quada,
    I’m an engineer with Teknic and came across your post. As a reminder, ClearPath and components have a 90 day money-back refund period. (You can place an RMA for refund with a couple of clicks on your webstore account).
    For users looking to purchase the kit, I wanted to point out a couple of things:
    • The ClearLink is an EtherNet/IP Step and direction controller but does not include specific functionality for CNC. This is used with an EtherNet/IP scanner, typically an EtherNet/IP PLC, such as an Allen Bradley Rockwell PLC.
    • For the ClearPath components, if you’re using the POWER4-HUB, you’ll also need:
    o PC-SBR-72 (DC Power Cable from IPC Power Supply to Power4-Hub)
    o CPM-CABLE-M2P2P-120 (24 VDC Power Supply Cable)
    • You need a micro USB cable designed for data communication (make sure it’s not just a charging cable).
    -Aaron B. Teknic Servo Systems Engineer
  1. Replies: 0
    Last Post: 09-06-2022, 05:17 PM
  2. Precision Matthews 1127 CNC Conversion
    By CL_MotoTech in forum Benchtop Machines
    Last Post: 02-16-2022, 02:41 PM
  3. started my cnc conversion for Precision Matthews PM-25MV Mill
    By rmachinist in forum Benchtop Machines
    Last Post: 10-01-2019, 09:50 AM
  4. Replies: 1
    Last Post: 02-02-2017, 09:01 PM
  5. Precision matthews PM-940M Mill to CNC conversion
    By unknownpro in forum Benchtop Machines
    Last Post: 11-28-2016, 08:42 PM
