586,103 active members*
3,593 visitors online*
Page 3 of 6 12345
Results 41 to 60 of 101
  1. #41
    Mar 2008
    454
    Re: Axis orientation flips
    ok I think I figured out what might have been causing that... the tool cutting edge may have been shallower than the pocket at that end due to the taper.
    By unchecking 'non-cutting portion' from gouge checking... i get this
    now I just need to add a stepdown since I dont want to cut the full depth in one shot, maybe 3mm per pass.
  2. #42
    Mar 2008
    454
    ok with 'axial cut depths' in roughing... I get what looks to be a good result!
    I was also able to re-check the 'non-cutting portion' on gouge checking... here is the result
    Let me know if you see anything I missed
ID:	492384Click image for larger version.
  3. #43
    Aug 2011
    252
    Quote Originally Posted by viroy View Post
    Let me know if you see anything I missed ]
    Looks good, if your happy with tolerances shown in simulation is ok.
  4. #44
    Mar 2008
    454
    is there a way to get the simulation to show the result compared to the pockets drawn?
    I cannot tell if the pockets are indeed cut right to the edge of where they are supposed to be
  5. #45
    Jun 2010
    4256
    As I said before you can not run A axis along Y, and swapping axis names will only confuse you.
    A axis is rotary along X axis, B axis is rotary along Y axis and C axis is rotary along Z axis.
    Ah well . . .
    I have done that in Mach3 - sort of. In Mach3 settings I put the A axis on the Y axis and it displays correctly, which is what I wanted.
    But otherwise there is no difference as far as Mach3 is concerned. If I issue g0 a90 the rotary unit rotates 90 degrees and that is all that matters for me.
    At the risk of being difficult, perhaps the problem is a limitation in the CAD/CAM SW? Maybe it is just refusing to do what you want? This does not happens to me as I program directly in g-code.
    Cheers
    Roger
  6. #46
    Aug 2011
    252
    Yes, the simulation always show the differences from part and machined part, that is the propose of simulation.
    https://www.cnczone.com/forums/attac...4&d=1682841296
    The colors shown in left upper corner are specific tolerances achieved after machining.
  7. #47
    Mar 2008
    454
    ahhh i missed that! so used to solidcam still
    Thank you so much for your help adi! You really came through on a difficult situation!!!
  8. #48
    Mar 2008
    454
    rcaffin, I havent checked the gcode yet but im hoping everything will be fine to load into mach3... and if it is like you say, I can define the B-axis as my rotary yes?
    I do have a true 4-axis machine with 4 independent controllers. so with the port settings I should be able to configure the rotary to any axis I like
  9. #49
    Aug 2011
    252
    Quote Originally Posted by RCaffin View Post
    Ah well . . .
    Cheers
    Roger
    Indeed, you can do that, but is not advisable. I make toolpats for 5 axis and even a single sign orientation of axis (+ or -) will ruin your part, or if is a symmetric part and the part come out ok, if you engrave text on that part, your text will be mirrored, not funny.
    That's why there is a standard for axis names and orientations. It's easier to change the letter of an axis and the orientation direction on controller side (software) to match your real machine.
  10. #50
    Jun 2010
    4256
    There is a world of difference between using a CAD/CAM package and doing all the programming yourself in g-code.
    In fact, the reason I tell Mach3 to put the A axis on the Y axis is so the display is how I want it. It works fine.
    Otherwise, you can make a CNC do anything you want if you program it directly. It helps to be able to visualise what you are doing of course.
    Yes, I realise that getting the sign wrong can have unfortunate results. But I always air-cut first, and watch closely.
    Cheers
    Roger
  11. #51
    Jun 2010
    4256
    Aircut first!
    Mach3 will sync all 6 axes together: X,Y,Z,A,B&C. That is a fundamental part of its design. Yes, you do need separate controllers for each axis - unless you are running two drives onto each side of one linear axis, but Mach3 can handle that as well. Mach3 seems to have a bit more flexibility than earlier commercial systems, which is nice.
    Cheers
    Roger
  12. #52
    Mar 2008
    454
    I do have one more thing I would like to accomplish...
    The wood blanks I get are usually square stock, I would like to mill it to the general shape of the tapered cylinder, mill the pockets, then take it to the lathe. (rather than lathe/mill/lathe)
    I will try this later today, but I'm guessing going about it the same way we just went through, except for the pattern upper/lower, use the two ends of the cylinder.
    I'm just imagining the ideal toolpaths here.... use a large square endmill to go longways along each of the 4 square edges to about the same height of the flat sides (resulting in something close to a cylinder), then spiraling down it with a ballnose to get a tapered shape roughly just a few mm above the final shape.
    What would be the best way to go about this?
  13. #53
    Aug 2011
    252
    Here it comes the hard part of the story, like I said before and many times you need to define your machine in MACH software to match your machine axis names and orientations, to be able to run a posted code with confidence.
    Also only this way, I can help you with a postprocessor that will work on your machine.
    Attachment 492396
    Check the axis from photo, also A,B and C need to have + or - direction, + for CW and - for CCW.
  14. #54
    Mar 2008
    454
    my machine is 24" x 48"
    the rotary is 36"
    The way it came and the way I have always done is the X-axis is 24" and the Y-axis is 48"
    So I run the rotary down the Y because its the only way it fits
ID:	492398Click image for larger version.
    From this photo angle, the bottom left corner of the bed would be the farthest negative X/Y
    So Y+ would run away from the camera, and X+ would go from the left side of the bed to the right side of the bed
    Rotary + would go CW to camera
  15. #55
    Aug 2011
    252
    the rotary is 36"
    You need to define your machine like that in MACH software and your rotary to be named Y. Here I can't help you as I don't use MACH software.
  16. #56
    Mar 2008
    454
    I dont understand why the rotary would be Y... I thought by defining 4-axis in camworks it would output the rotary as A or B
    I do need the ability to make flat spots on the rotary... a simple example would be, imagine the next operation after what was just done, is to make one end of the cylinder into a square
    Mach allows any input to be custom defined... if i wanted to, I can redefine any axis to any axis (so if i wanted to I could change X to Y or whatever)
    It deals with the raw input from controllers and has to be defined, so it does not know what motor is what axis, I decide that
  17. #57
    Aug 2011
    252
    Because in 4 axis, all axis move simultaneous at some point, so swapping only the axis name from X to Y and not the orientation will not work.
    Edit: If you want your rotary axis to be A, define your machine as X the longest travel (along the table) and Y the shortest.
    Because any CAD or CAM software will make the calculations from standard Cartesian coordinate system.
    https://en.wikipedia.org/wiki/Cartes...rdinate_system
    It's all about math...
  18. #58
    Mar 2008
    454
    I'm either missing the point or we are on the same page.
    The orientation defined in solidworks/camworks is identical to the exact orientation of all axis on my machine
    home will be center of the bottom (large) end of the tapered cylinder, X+ goes to the right of home position, Y+ runs up the cylinder from home, rotation + is CW
  19. #59
    Aug 2011
    252
    Then your good to go...
  20. #60
    Aug 2011
    252
    Defining your machine in CamWorks is only one easy task to display your part and toolpaths inside Solidworks, to output the g-code format suitable for your machine is the hard task that is handled by the postprocessor. To make a postprocessor that will work with your machine you need to have a kin file of your machine (kinematics), where are specified your axis travel, limits, orientations and so on.. Then the postprocessor need to be programed to output g-code format that your machine controller can handle. not an easy task, as I said before.
    P.S. If some administrator read this thread I think it belongs to CamWorks.
Page 3 of 6 12345
