586,106 active members*
2,987 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Intel I5 vs I9 in toolpath calculation time?
    May 2006
    309
    Will I save a lot of time in toolpath calculation if I buy a faster pc with a faster motherboard and a faster cpu?
    Anyone here with experience?
    Feb 2009
    2143
    Re: Intel I5 vs I9 in toolpath calculation time?
    You could use Task Manager to see if you get 100% CPU load when calculating now. If you have low CPU usage during the calculation, I would not expect to see much if any gain.
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
    I have a new i5 that's way faster than my old i7.
    It's going to depend on the software you're using. It might be a big difference, or it could be zero difference.
    If you are comparing processors from different generations, the newer one will most likely be better.
    As fast as my i5 is, I certainly wouldn't spend the money for an i9.
    Mar 2020
    thanks for the awesome information.
  1. SolidCAM G-Code Time Calculation.
    By Ivan-Ivanov in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 05-01-2017, 09:17 PM
  2. Toolpath calculation bug?
    By HubbleUp in forum CamBam
    Last Post: 02-17-2015, 02:03 AM
  3. Super slow toolpath calculation V23
    By Born2l8 in forum BobCad-Cam
    Last Post: 12-16-2010, 07:45 PM
  4. Machining time calculation
    By serhey778 in forum Material Machining Solutions
    Last Post: 04-09-2009, 12:39 AM
  5. Working time calculation
    By Ideas L in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-09-2007, 01:13 PM
