Ok I kind of understood that lol
Forgive me because the following follow up questions. They are really dumb and I know it. Teaching an old dog new tricks isn’t easy.
If both the proximity sensor (SN04-N) and the optical switch (OPB830) are rated for up to 30VDC the resistor is needed because of the mA my board would be sending? I'm assuming that's what you meant when you said, "it has to limit the current to 50ma max.”
It looks like from my board specifications that it is a 24v 500mA supply (page 64 of the manual).
The Optical switch has a max of 50mA but the Proximity sensor says 5mA.
So I’d need one resistor to bring one 24v supply from 500mA down to less than 50mA and another resistor on a 2nd 24v supply from 500mA to less than 5?
And I have absolutely no clue what to search for to get the right resistors for those. Any chance you could send me a link to them on say amazon so I know I’m getting the right ones?
Wiring for the optical switches:
Reds/anodes = power
The black wires, the cathodes, you said are grounds so they can be combined and grounded to the machine ground I have set up near them already?
White wires, the collectors, are combined in my current configuration but I still don't understand what they would connect to on my board. I’m kind of thinking they would be to the 0V input on my board as that is common for that series of inputs? But still confused.
And then the greens, the emitters, would go to the individual inputs in that section of inputs?
Or am I completely wrong as usual?
For the proximity sensors:
I get the brown/power wire.
The black is sending the signal which goes to the input on my board.
The specs I just found for this sensor shows the blue as 0V & ground so that could also go to the machine ground or does it need to go back to the 0V on my board?
I’m sure the link you sent with the electrical diagrams actually explains this but I get very confused looking at them.
Thank you again for putting up with my stupidity I'll owe you big time
