586,055 active members*
4,273 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Are my Opto switches NPN or PNP? & Do I need anything else to connect them to an MB3?
Page 1 of 2 12
Results 1 to 20 of 31
    May 2011
    104
    Question Are my Opto switches NPN or PNP? & Do I need anything else to connect them to an MB3?
    I know jut enough to be dangerous when it comes to electronics and need a guide for dummies on this.
    I am using OPB830W11Z slotted photo optical sensors for homing my CNC. https://www.digikey.com/en/products/...30W11Z/1637175 Been using them for almost 10 year. Now that I'm switching my controller to a Mach3Bob (MB3 with ESS) I need to relearn a few things. I can't tell if they are NPN or PNP which is kind of important for how I connect them to the MB3. I'm sure trial and error would work but I'd rather do it right the first time. I still get confused on which is which and which means normally open and closed. Again I need a for dummies guide
    Also on my current setup I have to use small break out boards for these sensors to then connect to the main controller board. Do I need separate BOBs for the MB3? I don't think I do but again want to make sure.
    Thank you in advance.
    Dec 2013
    5717
    Re: Are my Opto switches NPN or PNP? & Do I need anything else to connect them to an
    It would appear that they are NPN
    https://www.ttelectronics.com/TTElec...830_OPB840.pdf Look at the last page
    Jim Dawson
    Sandy, Oregon, USA
    May 2011
    104
    Thank you Jim. I have that data sheet and I figured something on there tells me but I'm not smart enough to know what it was. Which part tells me that for future reference?
    Dec 2013
    5717
    This picture. This is the symbol for a NPN photo transistor output
    Jim Dawson
    Sandy, Oregon, USA
    May 2011
    104
    Perfect, thank you. Looks like we are in the same neck of the woods as well. I'm tired of this cold!
    Dec 2013
    5717
    Quote Originally Posted by Dbl_Tap View Post
    Me too It's too cold in the shop to work.
    Jim Dawson
    Sandy, Oregon, USA
    May 2011
    104
    That's why I'm inside designing things in Fusion and asking questions on here lol
    24221
    Like many Opto's They can be used either way, IOW you can place the pull-up or pull-down on either the collector or emitter, this gives both options.
    The output is on the side of whichever has the resistor.
    Albert E.
    24221
    Here is an example.
    Albert E.
    May 2011
    104
    Here is an example.
    Thanks. Which configuration is the least susceptible to issues/noise/false trips?
    24221
    Electrically they are just about the same, it just gives you the option of pull-up or pull-down.
    Albert E.
    May 2011
    104
    Great thank you.
    24221
    Also check your input for opto isolated input, you may be able to eliminate the resistor by using your input device in place of the pull-up/down.
    Albert E.
    May 2011
    104
    I am almost positive I don't need anything to connect the limit switches and slotted photo sensors to my MB3 if I'm reading pages 16-20 correctly. Again I know just enough to be dangerous so I could be completely wrong. https://cncroom.com/wp-content/uploa...nual-E20R2.pdf
    24221
    Right yes, as in my last post, you can use the input Opto as the load for the external limit, IOW no pull-up or pull-dwn needed.
    Page #17.
    Albert E.
    Mar 2017
    411
    Just a quick note to demonstrate why one might be better than the other.
    It is always a good idea to configure your circuit such that if the cable breaks or becomes disconnected the limit switch will show as active. In this case, either circuit will do this. Also it is important to make sure that the circuit you design is tolerant of a short. In this case you may not want to use the pull-down circuit because it is vulnerable to, in a shorted condition, connect the unlimited +V to ground. Shorting your power supply rail to ground will affect the entire BOB and could cause physical damage. The resistor in the pull-up circuit will limit damage in a shorted condition.
    These factors show why it is often preferred to use NC, Normally Closed, switches and NPN sensors for limit sensing.
    Just my $.02
    May 2011
    104
    I've been running new wiring to everything and am just now getting ready to connect to the board. Of course, I thought I had it all figured out and now I'm not so sure.
    My limit switches three wire sensors. My last setup had all limit switches connected together which I planned to do for simplicity and less wiring. The board just needs to know the machine hit a limit, it doesn’t care if it hit the Y+ or the Y- independently.
    SO for the limits:
    Brown wire is power which will come from the 24v output on the board. I can understand that.
    The black wire goes back to an input, lets say X203 on my board.
    The blue wire I’m assuming would then connect to the 0V in the same port section?
    Assuming that’s correct the homing switches get me a little more confused on the connections. They are four wires.
    Black is the cathode. Now does that mean it’s a ground or is it the 0v? Can all of these be combined? I’m thinking so if they are 0V because I’d run out of those really fast on the board.
    Red is the anode which is power so that’s the 24v output. Easy again. All these can be combined.
    White is the collector and on my old board combining them was the way they were wired but I don’t know what this connects to on my board.
    Green is the emitter and don’t know what it connects to either.
    I know I’m being dense but this stuff isn’t my forte at all. I do much better with mechanics so I love being told put this wire in this spot on the board.
    Thank you again for putting up with the dumb questions.
    24221
    You are confusing/mixing valve (Tube) terminology with solid state.
    What are the part No.'s of the switches or a link?
    OK I see your first post, will look them up.
    Albert E.
    May 2011
    104
    The limit switches are SN04-N
    24221
    OK you will need a resistor in series with the diode which will go from the the +ve through a resistor to the top (anode) of input., the other cathode side goes to GND.it has to limit the current to 50ma max.
    So the value depends on the source voltage provided.
    The output can be connected direct to your input and configured as previous diagrams as sink or source.
    https://www.nutsvolts.com/magazine/a...upler-circuits
    Albert E.
Page 1 of 2 12
  1. Proximity Switch PnP or NpN, Realy or Resistor
    By Tazdingo in forum CNC Machine Related Electronics
    Last Post: 04-04-2019, 11:25 AM
  2. Wiring of npn inductive proximity switches.
    By wackocrash5150 in forum DIY CNC Router Table Machines
    Last Post: 01-17-2019, 11:49 PM
  3. Bypass NPN prox switches from PLC
    By leiryll in forum Mitsubishi controls
    Last Post: 09-26-2013, 06:56 PM
  4. PNP v/s NPN Proximity Switches
    By whiteriver in forum CNC Machine Related Electronics
    Last Post: 05-17-2007, 05:10 PM
