586,080 active members*
3,719 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Ceramill Motion 2 - 5 axis cnc - tool zero sensor wiring
Results 1 to 2 of 2
    Jun 2017
    5
    Hi Guys
    I have a mill i'm rewiring to a modern motion control board.
    I'm just trying to create the wiring diagram before I take it all a part, though ive hit a snag wire the tool zero sensor.
    It seems to be a magentic sensor that reads the movement of a metal anvil as it slides across the micro chip as the tool hits the arm.
    Does anyone have any idea what the wiring on the pcb would be?
    Jun 2017
    5
    Ok I found out the chip is a linear incremental position sensor, that uses reverse poles over the sensor to work out positioning. It’s a AS5306 sensor so it breaks the movement down into steps like a stepper motor encoder.
    Now just wondering if anyone has an idea how this could be connected to a UC300eth motion control
  1. Replies: 5
    Last Post: 12-31-2022, 02:36 AM
  2. Replies: 1
    Last Post: 01-01-2020, 12:15 AM
  3. New CNC for Plasma/Oxyfuel: Software , Motion controller (with THC) and Ohmic sensor
    By ARainho in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 10-14-2019, 05:45 PM
  4. Replies: 0
    Last Post: 02-13-2019, 10:37 PM
