586,070 active members*
3,556 visitors online*
Results 1 to 2 of 2
    Aug 2019
    Exclamation CNC controller xpthc-4h error E0
    Hi all.
    There is a problem with the plasma cutting machine. The next day after work, the z axis stopped working (it didn’t move up or down, but the movement indicators were on). After that, I replaced the controller and the axis motor, and a new error appeared. The controller gives an E0 error, which, judging by the instructions, does not even exist ...
    Plasma source LGK300HD.
    Perhaps someone has encountered such a problem and can suggest something.
    Aug 2019
    Re: CNC controller xpthc-4h error E0
    Hello everybody.
    With the error E0, to solve. It's the compatibility issue.
    For the XPTHC-4H, all parts in the set must be changed.
    After changing all the parts, the E0 error disappears and the system initializes correctly.
    Unfortunately I can't solve the problem with the Z axis.
    A good day to all.
  1. Post processor for sheetcam and cc-s3c and (THC) xpthc-4
    By brabirl in forum Post Processor Files
    Last Post: 02-16-2023, 07:41 AM
  2. My plasma torch not moving up and down..HYD-THC XPTHC-4H
    By dharnishpatel in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 03-04-2022, 09:04 PM
  3. CNC Plasma controller error
    By Bozgasergiu in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 02-02-2019, 04:50 PM
  4. cnc plasma control XPTHC-4 torch doesnt move
    By shakibdriss in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 05-23-2017, 07:42 PM
  5. Techno CNC Position Error No Power Controller :(
    By MJLadouceur in forum Commercial CNC Wood Routers
    Last Post: 12-02-2015, 02:14 AM
