586,065 active members*
4,861 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Multicam 3000 not saving parameters?
    Mar 2023
    Hi, I have a Multicam 3000 router. I bought it used and the last guy messed up the ATC parameters. So for now I am manually changing the tools. I have "Machine Tools Suite 4.0" , which has a couple of programs that allow me to make changes to the parameters. The main program, "MachineParameters4.exe" brings up a list of parameters with little input boxes. However, the parameters I need to change (900-950) do not have input boxes, so I cant make any changes. Under machine tools-->connection manager-->settings I can manually make changes to the XMI parameter file, but none of these changes are reflected in the machine. Does anyone have experience with this?
    Sep 2015
    8
    Re: Multicam 3000 not saving parameters?
    It is better to change parameters in motion mechanic or thru the keypad. 900-950 are tool change locations. A macro (program) is used to set the alignment of each tool position. Dont change any parameters unless you know what you are doing.
  1. multicam 3000
    By sawdust66 in forum Multicam Machines
    Last Post: 05-28-2022, 05:37 PM
  2. MultiCam 3000
    By Rusty48 in forum Multicam Machines
    Last Post: 01-09-2022, 02:10 PM
  3. Hi,im looking for a multicam 3000 tc manual, parameters
    By Dilalisima in forum Machinery Manuals / Brochures
    Last Post: 02-04-2021, 03:42 AM
  4. Multicam 3000 shutdown
    By Lilgedahl in forum DNC Problems and Solutions
    Last Post: 10-27-2018, 07:49 PM
  5. Multicam 3000 help anyone?
    By murfeedean in forum Multicam Machines
    Last Post: 05-22-2013, 05:02 PM
