586,114 active members*
3,319 visitors online*
    Strange alarm
    Hello im getting and alarm nobody i work with or even the boss knows whats up. It reads: 1185-20 ALARM A MCS VELOCITY DEVIATION OVER SPDL 7FFEFF53. Machine : L370. Control : OSP-E100L
    Dec 2008
    3109
    Re: Strange alarm
    I'd take a punt, that it is stating that there is a discrepancy in the spindle programmed RPM and actual RPM
    I'd start checking if any binding, any lub issues, any clamp/unclamp issues (might pay to remove and inspect hyd. clamp tube)
    These are the cheapest checks
    A wiring/ motor problem may need a tech and would need a few $$ thrown at it.
    Apr 2009
    1262
    Re: Strange alarm
    I’ve seen that alarm when the encoder is going bad. Sometimes you can adjust the gap to cure it, but usually it needs replacement. Superman is right when he says the motor and encoder are reading different RPM’s.
    Mar 2009
    1982
    Re: Strange alarm
    or just some dirt collected at the serrated wheel of encoder.
  1. Strange alarm.
    By EliseoMonteverd in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-02-2017, 04:05 PM
  2. Fanuc 6T alarm 212 strange problem
    By GITRDUN in forum Fanuc
    Last Post: 12-06-2012, 02:50 AM
  3. Strange Alarm
    By Patriot Jon in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-13-2011, 03:31 AM
  4. strange 021 alarm? - OMC
    By OC_ in forum Fanuc
    Last Post: 01-22-2008, 02:58 PM
  5. strange 021 alarm -OMC
    By OC_ in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-22-2008, 03:09 AM
