586,201 active members*
4,178 visitors online*
Results 1 to 1 of 1
    Sep 2008
    13
    Xilog/maestro issue
    Hi, Many of you might have seen this post under Vectric, but I haven't got any functioning answers so far, and since the problem is not in the Aspire PP but rather in the conversion from Maestro I'll try my luck here.
    I have a problem running aspire on my SCM pratix S12.As seen in the videoclip there is an extra z movment in between two toolpaths, there is, in the ISO-file produced by MAESTRO a couple of rows that is + or - 140 mm, these rows are not in the XXL file produced by my Aspire postprocessor. Most likely these movements are added somewhere in the translation process XXL>PGM>PGMX>ISO but I cant figure out where it come from. I tried to attach the XXL/ISO files but I dont know if I succeeded.
    Any help would be highly appreciated.
    Attached Files Attached Files
    Re: Xilog/maestro issue
    Can you zip your files and attach them please?
    Mar 2022
    28
    Yes, could you please zip your files? It looks like coordinates in NC code are higher that safe distance in the machine. This can made this movement.
