586,032 active members*
2,941 visitors online*
    Sep 2014
    15
    Mazak QT-6T X-origin Return Alarm 24 OVerload
    Hi, Good Morning
    Need Help.
    Mazak QT-6T
    When i Press X- axis Home origin, its gave a Emergency Alarm 24 OVerload (1, 0, &0058)
    Can anyone help me?
    Jan 2013
    474
    Quote Originally Posted by richxantan View Post
    Hi, Good Morning
    Need Help.
    Mazak QT-6T
    Can anyone help me?
    Did the axis move to it's + end position ?
    If yes, probably ran into the axis emergency overtravel switch.
    Sep 2014
    15
    Re: Mazak QT-6T X-origin Return Alarm 24 OVerload
    No. I need to try numerous times (Shut down the machine and Start the machine after an overload alarm) to return Home Origin for X-axis. However, if i run the machine with more than 5% Speed to run a program, it will gave a Emergency Alarm 24 OVerload (1, 0, &0058) after travel x-axis.
    Mar 2022
    Hi, Good Morning
    Need Help.
    Mazak QT-6T
    Can anyone help me?
    Dear sir, i have same machine but it loss tool data and tool life data. Could you give me this data. Thank a lot!
  1. Amada Vipros 358 King II Return to Origin without using G50
    By zer0blivion in forum Bending- and Punching Machines
    Last Post: 06-28-2022, 04:29 PM
  2. Just installed a RuiDa RDC6442G DSP - Doesn't Return to Origin :s
    By RatThing in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-31-2018, 08:29 PM
  3. Mazak QT20 T1 - Alarm 55 - Fanuc spindle drive overload
    By leito1489 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-21-2014, 01:24 PM
  4. Return to origin
    By pchfurniture in forum BobCad-Cam
    Last Post: 02-07-2012, 04:30 AM
  5. Origin and mazak??
    By Fendertok in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-13-2006, 01:06 AM
