586,058 active members*
4,270 visitors online*
    Mar 2023
    5
    Fluidnc in grblgru
    Any way to make fluidnc work in grblgru?
    May 2016
    333
    Re: Fluidnc in grblgru
    I do not know FluidCNC, but what I read is that it is based on GRBL. So if the USB protocol is the same as GRBL, it should work.
    I recommend just giving it a try. GrblGru is free
    Jul 2019
    FluidNC is a continuation of Bart Dring's ESP32 Grbl project. It should run with Grblgru signing in with the GrblMega5X controller option if using more than 3 axes. If only using 3 axes, the Grbl V1.x controller option should work. I haven't run FluidNC but I had ESP32Grbl running with Grblgru a year or 2 ago.
