586,106 active members*
3,199 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Eighty Three year old needs help in adding Hall effect sensors to DIY machine
Results 1 to 12 of 12
    Sep 2003
    1469
    My hardware
    Mach 3, Gecko G540, Warp 9 Ethernet Smooth Stepper, CNC4PC C25S-SMOOTH STEPPER LPT BOB.
    Built my present CNC from scratch over a decade ago and love it. Now I’m ready to go to the next level with some Hall Effect Sensors. About 18 years or so ago I built my first CNC, and upon firing it up I lost the Magic Blue Smoke, so now I don’t do anything electronically I don’t understand.
    There are multiple pages of electrical jargon below, what I want to do is have the below Hall Effects work with the above BOB so I can eventually run the 2010 Screenset I have had for years but yet to run the homing, axis zeroing and many other desirable functions.
    Please do not reply with technical terms such as VXXO or the such. If you could dumb it all down to point to point drawings I will be so happy. REMEMBER I’m 83.
    Hager
    15362
    Re: Eighty Three year old needs help in adding Hall effect sensors to DIY machine
    Quote Originally Posted by Mr.Chips View Post
    My hardware
    Hager
    Why would you waste your time with Hall affect sensors when you can buy cheap Proximity sensors or even Micro Switch's that will do a better and easier to setup and install. just mount and wire to the breakout Boards inputs for Homing and limits.
    Mactec54
    Nov 2012
    1267
    I agree with Mactec. Hall sensors have their place, but this is not it.
    Inductive proximity switches is what you want. They are cheap, rugged, reliable, reasonably accurate, simple to install. Follow the diagram in your manual (the page that says "5.2 Connecting NPN sensors").
    Here are some common Chinese part numbers (choose one). Those are all normally open NPN switches.
    LJ8A3-2-Z/BX - thread diameter 8mm, detection distance 2mm.
    LJ12A3-4-Z/BX - thread diameter 12mm, detection distance 4mm.
    LJ18A3-5-Z/BX - thread diameter 18mm, detection distance 5mm.
    LJ18A3-8-Z/BX - thread diameter 18mm, detection distance 8mm.
    https://www.ebay.com/itm/16110648972...item2582b1f17f
    24221
    There seems to be some confusion on the definition, there are five types of electronic proximity sensors, these include Capacitive, Inductive, Magnetic, Optical, and Ultrasonic.
    The most common, inductive (Hall) proximity sensors, uses the Hall effect also.
    The change in the effect on an oscillator when a selected material is brought close to the sensor.
    It would seem the OP has selected linear versions, which are not suitable for this application.
    Albert E.
    Nov 2013
    4376
    snap action microswitches work perfectly well, are reliable, repeatable and most importantly for OP dead easy to understand and wire up.
    https://nz.element14.com/omron-indus...15a/dp/1500340
    Craig
    Sep 2003
    1469
    OK, you talked me into Proximity sensors, I want the normally closed type PNP I think, please let me know if this is wrong?
    The three wires are connected to +V, —V, and the third an Input pin on the BOB, Is this correct?
    I see many wiring diagrams that use a relay, I don’t think that is necessary, correct?
    The Proximity sensor I’m looking at operates at 6 to 24V and it would output the same to the input pin. I’m thinking to supply 12V to the sensor (should be better than the lower 6V) and reduce that 12V to the input pin using a resistor. Is this Reasonable, and what resistance? OH SO MANY QUESTIONS. I lost the magic blue smoke out of my first CNC many years ago, and need to do this correctly.
    Thanks (Be Gentle, LOL)
    Nov 2013
    4376
    you claim to be an electrical/electronic illiterate correct? Then why use prox sensors which require a modicum of both?. Whats wrong with microswitches?
    Craig
    24221
    For one, I find the manual on the C25S manual to be very poor as many of these Chinese etc Items are, and as mentioned in post #3, there is a diagram for connecting 3 wire proximity switches on P5.2.
    It is also strange that this BOB does not use isolated (Opto) I/O?
    Albert E.
    Sep 2003
    1469
    Craig
    while it may be more complicated but with some good help it can be done and be more reliable and exact than switches. I’m also going to use the C25 BOB, it is much more user friendly especially when it comes to the C25 positive screw type connections not the jumbled spring wire connections of the C25S
    Sep 2003
    1469
    I’m ending this thread and will start up a new one using the C25 BOB, ESS Smoothstepper and proximity switches .
    Thanks you all for the advice and help.
    Nov 2013
    4376
    I use good quality snap action microswitches, and have done for many years and get better than 0.02mm repeatability with them.
    Craig
    15362
    Good idea, getting back to the proximity switches NPN normally closed would be easier to use, you can wire them directly to an output on the Breakout board, no extra 24v supply needed, they work fine with the low voltage especially for a hobby install.
    Mactec54
  1. Help setting up Hall effect sensors on Mach3 BOB CNC
    By Mr.Chips in forum CNC Machine Related Electronics
    Last Post: 07-27-2021, 08:05 PM
  2. Replies: 1
    Last Post: 07-26-2021, 04:51 PM
  3. Using Hall Effect sensors as limit/home switches
    Last Post: 07-26-2021, 06:59 AM
  4. Hall effect sensor
    By BillScheltema in forum CNC Machine Related Electronics
    Last Post: 06-03-2010, 11:32 PM
  5. Hall Effect Chopper
    By legomanww in forum CNC Machine Related Electronics
    Last Post: 12-20-2007, 09:11 AM
