586,635 active members*
2,983 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > DOOSAN DMV 3016Ld Lubricant Recommendations/Help
    Mar 2023
    5
    Question DOOSAN DMV 3016Ld Lubricant Recommendations/Help
    Hello,
    Our shop has a Doosan/Daewoo DMV 3016Ld CNC mill and we currently use Mobil Vactra Oil No. 2 for lubrication. Unsure if it's supply issue related, but can't seem to source this oil currently: have two active orders, both backordered until April at the earliest.
    Closest I've found as an alternative was Mobil way oil, SAE grade 30, ISO grade 68, but worried that since our current lubricant is SAE grade 20, there will be some machine issues/etc.
    Anyone have a similar machine? If so - what are you using?
    Other info: tried contacting Doosan for recommendations as well, no word yet. Did find Shell Tonna T 68 oil - doing more digging to see if that's something that will work.
    Thanks in advance!
    Mar 2015
    47
    Re: DOOSAN DMV 3016Ld Lubricant Recommendations/Help
    Greetings,
    McMaster-Carr...
    https://www.mcmaster.com/products/wa...e~vactra-no-2/
    Cheers,
    Dave
    Jan 2013
    474
    Quote Originally Posted by bwcove83 View Post
    Hello,
    Thanks in advance!
    Shell Tellus 68 would work ok.
    Mar 2023
    5
    Thanks so much, Dave!
    - - - Updated - - -
    Thanks - will look into Shell Tellus.
