587,040 active members*
2,860 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanucu parameter for changing rapid speed
    Mar 2023
    Good morning I have a little problem with my Victor
    VTurn 36
    1998
    Fanuc Series O-T
    0669-07
    Servo: 9046-09
    PMC: OLSP-1
    Can someone know what i must change in parameters.
    Problem is when i use knob from rapid feed when i setup on 0% machine should stop but still going in Z and X 398-401mm/min and this is not rhigt because should stay stopped.
    Knob is ok because feed is changed
    Rapid Z X
    0% 398 401mm/min
    25% 3750 3000mm/min
    50% 7500 6000mm/min
    100% 15000 12000mm/min
    All solutions which i found is for new Fanuc and this one don't have so much parameters numbers. Even if i do Rapid and Work feed on 0% machine stil slowly going till see in program G1 then stop because on work feed when knob is on 0% and is ok
    Dec 2008
    3122
    Re: Fanucu parameter for changing rapid speed
    I too, have O series control where 0% is not zero, it is about 1% of actual rapid rate....
    The only way, to have a "zero" rate, would be to use "dry run" which uses feedrate override control which does go down to zero, the downside is the maximum override rate is a lot, lot less than the machine's rapid rate.
    0393 bit 5 STOVO
    1: Feedrate override 0% stops rapid traverse
    0: Feedrate override 0% does not influence rapid traverse
  1. Replies: 3
    Last Post: 03-05-2019, 11:57 AM
  2. Replies: 7
    Last Post: 12-07-2014, 03:23 PM
  3. changing rapid travel on jog
    By cSpampinato in forum Hyundai Kia
    Last Post: 08-21-2012, 04:02 PM
  4. Rapid speed parameter M32
    By MIKEL12 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-08-2010, 10:41 PM
  5. Rapid speed parameter in a ES-L6 with OSP U10L?
    By aaroncswenson in forum Okuma
    Last Post: 05-17-2010, 03:24 PM
