587,047 active members*
2,695 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma axis motor question and error code
    Nov 2013
    26
    Hi. My Z axis motor got hit hard enough to fracture the motor end cover. Although the encoder looks OK, I am getting an error "065 ALARM P" "SVP start 1021A08"
    It also says Memory Test OK, Load SYS
    then: EC PROCESSOR ON INITIAL PROCESS
    SERVO PROCESSOR ON INITIAL PROCESS
    SBP MONITOR
    >_
    Can anyone tell me if this is likely due to the encoder or some other cause?
    I was looking at used encoders and it seems almost the same price to buy the whole motor including encoder, plus it hasn't been pulled apart.
    The part number on my motor is BL-MH101E-12SB
    Can anyone tell me if there is a difference (that matters) with a BL-MH101E-12S ?
    Both are 1200rpm, 6 pole, 155v, 5A, 1.2KW and have same encoder, ABS-FB-D2048
    Also, are any other the newer encoders directly interchangeable?
    Thank you,
    Bryan
    Jan 2013
    474
    Quote Originally Posted by bryanbdp View Post
    SBP MONITOR
    >_
    Thank you,
    Bryan
    The Okuma axis motor has an absolute encoder.
    It's possible it's damaged and not communicating.
    Swap encoder input cable with another drive and see if the fault moves with the cable.
    Nov 2013
    26
    Quote Originally Posted by servtech View Post
    Thanks for the reply. I ordered another encoder to swap.
    I also determined the -SB suffix is servo with brake. Shouldafigured that one out!
    Nov 2013
    26
    New(er) encoder did the trick. Machine started up and ran well! Very exciting!
    Mar 2009
    1982
    Re: Okuma axis motor question and error code
    should be easy to fix old encoder.
