586,080 active members*
3,622 visitors online*
IndustryArena Forum > MetalWorking Machines > Turning Machines > Techno CNC Lathe ignores X offset
    May 2018
    85
    I just brought home a 20 y.o. Techno CNC Servo Lathe, my first lathe after many different routers. It's an educational machine so the control is very simple, MFR claims it is Fanuc compatible, machine is no longer supported.
    I've chucked my 1.527" stock and set the 0,0 to the front outside corner of the stock. The setup in the control has an offset for X & Y, and the X offset is set to -0.7635" which should indicate Z axis center. Tool offset is at 0,0 (which it seems to ignore anyway).
    I have run the program several times with different offsets for X and T1 and the tool always starts at 1.433" (first pass depth) from the outside of the stock. Z starts in the correct position.
    CAM is Fusion 360 with a generic Fanuc post processor (the only post I can find). The program is using G54. G code is attached.
    I'm sure the answer is simple, thanks for any help.
    Aug 2004
    780
    Re: Techno CNC Lathe ignores X offset
    The answer is actually very complex for endless reasons.
    There are 16 million different combinations of offsets for std gcodes, if they are all implemented and work correctly, which they won´t-
    and the correct working is actually not quite clear.
    And more/less all controllers do not work correctly with *some* combinations of gcode, perfectly good gcode.
    Endless technical reasons for it, mostly meaning they did not code properly, then, or even now.
  1. KFlop+KStep Lathe - G-code M06 ignores tool offsets
    By eerohaahti in forum Dynomotion/Kflop/Kanalog
    Last Post: 07-25-2018, 09:06 AM
  2. Techno cnc Lathe
    By lentzie in forum Education - Teachers and Students Hangout
    Last Post: 11-28-2015, 03:10 AM
  3. Machine ignores offset
    By shisik in forum G-Code Programing
    Last Post: 02-11-2015, 03:37 AM
  4. Techno CNC Lathe Manual
    By jkaprocki in forum Machinery Manuals / Brochures
    Last Post: 08-30-2014, 01:41 PM
  5. Post Processor For Techno CNC Metal Lathe
    By Hodgson in forum EdgeCam
    Last Post: 01-17-2012, 11:07 PM
