586,123 active members*
3,237 visitors online*
IndustryArena Forum > CNC Electronics > Leadshine > Leadshine vs other Chinese brands
    Apr 2015
    6
    Question Leadshine vs other Chinese brands
    how does Leadshine compare to other Chinese AC Servo manufacturers like rtelligent/lichuanmotor/dorna?
    Also I have trouble finding any direct sellers of Leadshine on Alibaba/AliExpress is that normal?
    Re: Leadshine vs other Chinese brands
    It also need to think about your gear size ,gear box or motor reducer ,motor nm etc when choose servo motor, hope i can help you +8618560201508
    Nov 2013
    4376
    have you looked at Delta, they are a step up from all those you mentioned.
    https://www.fasttobuy.com/Supply-asdab2-series_c498
    Craig
    Apr 2015
    6
    Step up as in higher quality hardware or just because the software is so much better and makes tuning so much easier?
    Nov 2013
    4376
    both probably, but I as I don't have a Leashine servo so it would be unfair to make comment about quality of the hardware, but most certainly the set-up
    and tuning software puts Delta head and shoulders above Leashine, especially is this is your first foray into servos.
    All servo manufacturers tend to copy each other and despite different terminology if you can setup one servo then there is a high probability that you can set up
    another, but having software to aid that process is invaluable, especially at the beginning.
    Craig
  1. Buying a laser cutting and engraving machine CHINESE BRANDS
    By KRASI in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-17-2018, 07:57 AM
  2. Are Chinese servos a gamble? Servos vs Leadshine closed loop
    By j3dprints in forum Servo Motors / Drives
    Last Post: 01-05-2018, 07:09 AM
  3. Laser Cutting Speed Comparison - How do Chinese and Top Brands Compare?
    By tperceval in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-22-2016, 07:29 PM
  4. Laser Cutting Speed Comparison - How do Chinese and Top Brands Compare?
    By tperceval in forum Complaints and Praise Discussions
    Last Post: 06-14-2016, 06:48 PM
  5. C6 brands?
    By cnczoner in forum Uncategorised MetalWorking Machines
    Last Post: 07-18-2008, 06:48 AM
