586,077 active members*
3,827 visitors online*
    Sep 2005
    274
    Hardinge conquest GT27 SP
    Hello I was wondering how do most people set up there tools on a Gang tool lathe, do you keep them in order 1234 from front to back etc or are they all over the place, do you stick out your turning tools to allow for the length of the part or do you have the turning tools go pass on the side. how about a cut-off tool do you keep it on the front or the back of the slide? I guess it all works, just wondering what's the best way to go. thanks.
    Dec 2008
    3109
    Re: Hardinge conquest GT27 SP
    I was under the belief that the most common crash is between chuck jaw and adjacent tool next to the one in-use.
    I set tools depending on Z distance to next tool AND where it is used in the X axis
    Ie. Boring bar & drill NOT next to each other when machining short stock
    It should also be considered on the quantity you need to make... if you can knock seconds off per cycle on a large quantity run can save many hours.
    Take care on proving first run.... it would miss for the others, if there is no change.
  1. Hardinge Conquest GT27 Fanuc 18t Control
    By moso in forum Hardinge Lathes
    Last Post: 11-15-2022, 01:20 PM
  2. Hardinge GT27 Fanuc 18t Control lube problem
    Last Post: 08-07-2022, 08:17 AM
  3. Re mapping X- Jog Arrow Hardinge GT27 Fanuc 18T
    Last Post: 02-21-2014, 06:34 PM
  4. Hardinge Conquest 42
    By newc in forum Hardinge Lathes
    Last Post: 02-25-2010, 01:10 PM
