586,077 active members*
3,870 visitors online*
    Apr 2015
    6
    Question Belt gearbox for helical rack
    I'm seeing these belt gearboxes all over the internet. Anyone has any info on them? Are they good/bad idea? And looking at the price why would you use this over a cheap-ish planetary gearbox with less than 15 arc-min backlash?
    Re: Belt gearbox for helical rack
    Belt drive probably has less backlash than 15 arcmin.
    Gearboxes tend to be higher reduction, and are designed to work with servo motors.
    5:1 belt drive is designed for stepper motors.
    Apr 2015
    6
    Realistically speaking how much backlash does this thing have? less than 10 arcmin? Less than 5? Even lass than that?
    Nov 2013
    4375
    you may be getting hung up on the backlash in either the gear or belt drive, but the biggest source of lash is between
    the pinion and rack.
    Lets say the lash between the pinion and rack amounts to 0.05mm (approx 2 thou) then the extra lash contribution by the gearbox/belt drive is another
    0.01mm (approx 8/10ths) then who really cares? Even if you spent thousands of dollars on a gearbox and got zero backlash the lash between pinion and rack will still be
    there and totally dominate the lash equation.
    Craig
  1. Planetary gearbox Or belt reduction
    By assadi in forum Mechanical Calculations/Engineering Design
    Last Post: 04-25-2017, 09:33 AM
  2. Helical Rack - would you prefer it to spur rack?
    By Diane-MooreGear in forum Linear and Rotary Motion
    Last Post: 10-01-2012, 08:02 PM
  3. Belt vs Gearbox drive system
    By Redgoatfab in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 01-29-2012, 04:29 PM
  4. Virgin CNC'er Rack/gearbox vs Belts
    By xrayxray in forum DIY CNC Router Table Machines
    Last Post: 01-04-2012, 10:37 PM
  5. rack and rack & pinion with off the self planetary gearbox
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 12-06-2009, 03:54 PM
