586,103 active members*
3,048 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > DOOSAN S310N Alarm code 2024
Results 1 to 8 of 8
    Nov 2008
    36
    Can anyone help me clear this alarm
    Jan 2013
    474
    Quote Originally Posted by jeffm View Post
    Fault text ?
    Permanent?
    Intermittent?
    When did it occur?
    Nov 2008
    36
    Re: DOOSAN S310N Alarm code 2024
    It was running fine and it went to index for the cut off tool and this is what I got
    Dec 2012
    395
    What brand turret, it's a Doosan alarm, did it throw a message for 2024.
    Probably a proximity sensor.
    Do you have the Electric Circuit / Ladder Diagram [Blue] Book, it contains all the alarms out there for your machine.
    Nov 2008
    36
    let me see if I can attach the picture againAttachment 491348
    Dec 2012
    395
    Try to do a tool index and look if the orange LED switches for one side to the other on the hydraulic solenoid (valve) for "lifting/releasing" the turret.
    If it works the proximity sensor inside the turret could be the issue.
    Nov 2008
    36
    I figured out that the solenoid was stuck. I just pushed the shaft with an allen wrench to free it up and now it seems to be working. Thanks for taking the time to all for your input
    Dec 2012
    395
    Okay, no problem, ..... glad it's working again.
