Hi All - I am starting on the design of a full sheet router and want to build the gantry longwise not trans. This is to allow easier loading of the sheet. This means the gantry will be 2.9 to 3.0m long. There are lots of industrial machines with gantries this wide. So I'm wondering what size gantry section should be used. Plus I want to build it using aluminium/timber laminates or some exotic organic spaceframe if it proves its worthwhile. So I started with a 150x150x10mm steel SHS as a benchmark. There is a 200x10mm aluminium extrusion I want to use which makes the gantry 200mm wide. I modelled a 150x150x10 shs section 3m wide plus the proposed Lamio gantry. The steel one weighs 104kg the Lamio weighs 97kg. I have recently made a small scale lamio gantry for a small router called Frankie. It used 3mm aluminium sheet and 30mm pine as the laminates. So far its proved to be damp and stiff. I suspect that the 150x150 is too small for a 2.9m span. I will research whats out there. If anyone has a suggestion from experience I'd appreciate the input.
So to the results: I modeled Lamio and the SHS in Fusion then brought those into simsolid. I have a Z axis that is "rigid" ie it can't deflect so the only deflection is the gantry. I set up the restraints and loads so the moments applied to lamio and the 150SHS where the same. In the push dirn Lamio is stiffer mainly due to its a solid so does not lozenge. Lamio 147um (70%) SHS 211um. Trans dirn Lamio 10um (125%) SHS 8um and the plunge dirn Lamio 146um (131%) and SHS 111um. So overall similiar but can change Lamio to catch up. I suspect something like 200x200SHS will be needed. A little more research on what's out there is needed... Peter
