586,106 active members*
3,113 visitors online*
Results 1 to 9 of 9
    Apr 2023
    mazak 30/50A spindle motor control malf
    Old mazak 30/50A with Mazatrol Camm-2 controller coming up with a Spindle motor control malf, error code 251, had other errors before this but it went away then came back, any help would be appreciated
    Jan 2013
    474
    Quote Originally Posted by Dara01 View Post
    This is a Mitsubishi control tailored as Mazatrol, is there text with the alarm, maybe post a photo of the screen?
    The only 251 errors I can find state either a lathe spindle is blocked due to chuck open signal or milling spindle tool not clamped signals missing.
    15362
    Re: mazak 30/50A spindle motor control malf
    251 is a PLC Alarm
    Does your mill have a B axis?
    251 MILLING MOTOR ROTATION PROHIB
    A milling spindle rotation command was given even though the milling tool was not clamped.
    A milling spindle rotation command was given with the door not closed when the door interlock switch was set to AUTO. [When the door interlock option is provided.]
    So just 2 things here to check is that the Tool is getting the clamped signal.
    The Door interlock is working or bypassed.
    Mactec54
    Apr 2023
    Quote Originally Posted by servtech View Post
    Hard to see anything on the screen in a picture, but here's the manual 251 fault it doesnt help much
    Jan 2013
    474
    Definitely a plc fault.
    Check chuck clamp limit and pressure switches.
    15362
    If he has a 30/50A that is a mill not a lathe
    Mactec54
    Apr 2023
    Yeah it's a mill not a lathe sorry, there was parameters missing but we got them back then this error popped up
    Jan 2013
    474
    In that case, check tool clamp unclamp signals. If the plc input signals are incorrect the spindle won't be released to run
    15362
    Its all in Post #4
    Mactec54
