586,471 active members*
3,347 visitors online*
    Nov 2007
    361
    PS0317 Alarm while threading
    We just bought a Hwacheon hi-tech 200 B it has a Fanuc oi-TD series control, this is the 1st time this machine has cut any single point thread, while it has done some tapping as a matter of fact that is all this machine has even done is face, drill, bore, and tap. We are trying to cut a 1/2" -14 npt internal thread using G76 canned threading cycle , we brought over a program that has been proven on a Doosan Puma 300 and loaded it into the Hi-tech 200 and we keep getting alarm PS0317 ( Illegal thread command is in the thread cutting cycle ) when it reads the 2nd G76 line, I have changed every single variable in both G76 lines with no success and like I said this is a proven program from another machine that is running Fanuc i-series controls. I listed the program below, but I am thinking there is maybe a parameter that has not been setup and it is making this alarm. Does anyone have the parameter list that is associated with G76 threading, I have all the parameters, but I need to know what parameters the G76 canned cycle uses so I can check them to make sure they are set right?
    n2 (SIR 0500 M16B threading bar with 16IR AG 60 IC250 insert )
    G0 T0606
    G97 S300 M3
    G0 G54 X.5721 Z.2253
    G76 P010029 Q20 R20
    G76 X.8412 Z-.88 P571 Q100 R.0336 F.07143
    G0 Z.2253
    G28 U0. W0. M5
    T0600
    M1
    Apr 2009
    1379
    Re: PS0317 Alarm while threading
    The control may not have that option enabled.
    Nov 2007
    361
    I found the problem the difference from this series fanuc and the doosan is the on the 1st g76 line the r value needed a . So ( R.002 ) rather than R20
  1. Chinese CNC Controller Throwing Alarm While Threading
    By asql2580 in forum Turning Machines
    Last Post: 01-28-2021, 02:13 AM
  2. Replies: 2
    Last Post: 04-11-2019, 05:40 PM
  3. Okuma OSP Lathe Threading G32 Alarm
    By dustpan3 in forum G-Code Programing
    Last Post: 10-31-2016, 10:47 AM
  4. Mitsubishi CNC on lathe: alarm light flickers while threading
    By HuFlungDung in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-11-2009, 10:19 PM
