586,121 active members*
3,556 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Need Help on 7.5 kw vacuum pump Chinese's water filled tank.
    Oct 2013
    114
    Post Need Help on 7.5 kw vacuum pump Chinese's water filled tank.
    hi
    The temperature is while running 2 min reached to 75 degrees motor body temperature.
    is this normal temperature?
    the inrush current is 95 to 100 amps and the running amps is 15 A
    Oct 2013
    114
    Re: Need Help on 7.5 kw vacuum pump Chinese's water filled tank.
    Quote Originally Posted by M.Abid View Post
    hi
    correction its 23 min not 2 min
    15362
    hi
    Is that Single Phase startup Amps or 3Phase. are you using a VFD Drive for the Vacuum Pump or is it directly connected to a starter.
    The temperature is fine, normal is around 60° but can go much higher than your 75°
    Mactec54
    Oct 2013
    114
    Hi bro its three phase startup Amps 95 to 100 and running 15 amps continues.
    Currently its directly connected to simple On / off isolator.
    But planning to connect with star delta starter.
    This is 7.5 kw 10 hp water tank pump is this over size pump ffor 1.5 x 3 meter cnc bed.
  1. Gast Vacuum Pump Operation for Vacuum Table
    By trdodger in forum Signmaking Topics
    Last Post: 09-16-2022, 02:29 AM
  2. DIY Vacuum Pump for 4x6 vacuum bed
    By 1Jumper10 in forum Work Fixtures / Hold-Down Solutions
    Last Post: 06-18-2018, 11:31 PM
  3. TM1P - you need this new tank and pump
    By paradiddle1 in forum Haas Mills
    Last Post: 05-20-2016, 05:52 PM
  4. Vacuum pump size for vacuum hold down jig?
    By dawgwalker in forum Work Fixtures / Hold-Down Solutions
    Last Post: 08-21-2014, 03:07 AM
  5. portable and lightweight fixed-gantry router - water filled tubes?
    By dmorton in forum DIY CNC Router Table Machines
    Last Post: 10-09-2011, 04:51 PM
