586,116 active members*
3,469 visitors online*
    May 2012
    32
    CNC Lathe turret coolant
    Hi There,
    We recently purchased a Takisawa TC30 and it was used for production of what seems to be cast iron.
    I have rebuilt the coolant pump but found the coolant supply issue is in the Turret coolant paths.
    has anyone dealt with cleaning the coolant passages ?
    Jan 2013
    474
    Quote Originally Posted by Jones'r View Post
    Hi There,
    Cast iron can be a disaster for coolant galleries, also the pump impeller which can look ok but be reduced in diameter by cast iron powder, reducing its efficiency. Check the impeller diameter is correct for the pump.
    Check that the in line check valve isn't stuck partly closed or stuck further reducing flow, delaying coolant to the turret tool.
    Remove all the pipes and blow them through.
    With pipe disconnected from the back of the turret, index to each turret position and blow backwards from the turret end to clear the cast iron debris.
    Reconnect everything and run a flushing agent through the system.
    Test again.
  1. CNC Turret Lathe for my garage.
    By adamant in forum Want To Buy...Need help!
    Last Post: 01-13-2015, 08:06 AM
  2. Clogged coolant between turret housing and turret
    By autotrol9 in forum Hyundai Kia
    Last Post: 07-10-2014, 10:40 AM
  3. Rebuilding my cnc turret lathe
    By jasminder in forum Vertical Mill, Lathe Project Log
    Last Post: 05-13-2011, 07:12 PM
  4. Turret lathe CNC retrofit?
    By MattiasCarlsson in forum Uncategorised MetalWorking Machines
    Last Post: 01-05-2009, 12:15 PM
  5. Turret for a cnc lathe
    By mtechserv in forum Uncategorised MetalWorking Machines
    Last Post: 02-18-2008, 12:01 AM
