586,106 active members*
3,327 visitors online*
Results 1 to 6 of 6
    May 2020
    12
    limit switch DMU 60 E1
    Are there limit switches for the axis or are they integrated in the glass scales?
    kind regards
    Jan 2013
    474
    Quote Originally Posted by peco2002 View Post
    kind regards
    They can be parameter soft limits or sometimes use a marker on the scale. Or even an end limit switch.
    Can you post an electrical drawing of an axis page ?
    May 2020
    12
    Re: limit switch DMU 60 E1
    thx for reply
    in attachment you can find schematic of x, y and z axis..
    kind regards pedro
    Attached Files Attached Files
    Jan 2013
    474
    thx for reply
    kind regards pedro
    The drawing do not show any switches, just motor encoder and scale.
    There may be a reference switch on an input drawing. Ref X schalter for example.
    With incremental scales there can be a switch, with absolute scales, usually not.
    Increment scales would need a switch at the end of the axis travel.
    With absolute scales the axis normally only needs to travel across several markers to know it's position.
    Both cases a zero shift parameter to optimize the zero position.
    Mar 2021
    14
    If you reference your machine on each power up then yes, it touches the limit switch, then travels to the home pulse on the scale.
    Dec 2022
    11
    Good day,
    Could you please share the wiring diagram
  1. Replies: 1
    Last Post: 10-12-2020, 09:23 AM
  2. Limit Switch in DSP0501 - Can I use a simple NO switch as limit switch
    By silver_fx in forum CNC Machine Related Electronics
    Last Post: 08-24-2020, 12:23 PM
  3. MACH 3, Warp9 smooth stepper, Leadshine mx4660 Limit switch home switch woes HELP
    By cabinman in forum Mach Software (ArtSoft software)
    Last Post: 01-14-2018, 08:26 PM
