586,094 active members*
4,177 visitors online*
IndustryArena Forum > CAM Software > MadCAM > MadCam doesn’t work on new computer
    Jun 2012
    15
    I have installed Rhino 7 and MadCam7 on a new Asus lapto running Windows 11.. Rhino seems to working fine. MadCam loads and all icons appear normal. However, when I select a model and select the tool icon nothing happens. When I click on the tool icon a second time, I get the following message: “The name/key you entered does not appear to be valid.”
    I have re-installed both Rhino and MadCam several times and have verified the location of the machine library, postprocessor, and tool library.
    Any suggestions?
    Jerry
    Nov 2013
    36
    Re: MadCam doesn’t work on new computer
    I had this problem when transferring license to a new computer. If possible, unregister your old computer and then try it. That worked for me. Otherwise, email Joakim to reset your license for the given serial/email.
  1. What versions of MadCAM work with Rhino 7?
    By arvidj in forum MadCAM
    Last Post: 12-06-2020, 11:24 AM
  2. Replies: 0
    Last Post: 05-13-2018, 09:10 AM
  3. Will latest Madcam work with Rhino 4.0
    By brian257 in forum MadCAM
    Last Post: 03-31-2015, 09:37 PM
  4. Show some of your Madcam work
    By turmite in forum MadCAM
    Last Post: 01-10-2013, 04:58 PM
  5. New Computer - MadCam Won't Work
    By jawaba in forum MadCAM
    Last Post: 03-03-2010, 04:23 PM
