586,655 active members*
2,483 visitors online*
IndustryArena Forum > Mechanical Engineering > T-Slot CNC building > Large Extruded Tslot Gantry Beam Sources
    Jun 2020
    Hi all, I've been surfing the subforum hoping to find some sources for large gantry beam profile, hopefully US based. I've looked at 80/20 but largest I could find there was 3"x 6" or 80x160. I se what looks to be larger profile on some of the YT builds. Was interested in something closer to 80x200. Any suggestions?
    I've seen references to cncrouterparts.com as a source but everytime I try to track that down I just end up at AVID cnc. Any sources for larger higher end DIY parts would also be appreciated. Sources for the small low end stuff are abundent.
    Thanks in advance,
    Best,
    Kelly
    Jul 2018
    6427
    Re: Large Extruded Tslot Gantry Beam Sources
    Hi Kelly - cncrouterparts changed their name to AVID some time ago. So they are the same company. I suggest you look at standard extrusions something in a hollow rectangle 200x80. Here in Oz I can get heavy wall 100x100 and use two of them. makes a great gantry. Peter
    Jun 2022
    58
    here are a few I had saved when I was considering the T extrusion...
    Hope it's helpful...
    https://parco-inc.com/product-catego...minum-framing/
    https://www.alineautomation.com/prod...200-heavy-duty
    https://8020.net/shop
    Paul
    Apr 2007
    1955
    Thanks for the resource list.
    I just purchased some items from parco. They have larger items that I didn't find anywhere else.
    Very happy with the parts.
    I have also purchased a few related items from Mcmaster.
    Sorry for the picture quality - not sure why it looks off. Maybe compressing the photo from 10 mb to 250 k was too much.
    This is just a sampling of some 15 series stuff.
Name:	2023 oct 06 gusset and brace parts sq m cmp.jpg
    Apr 2007
    1955
    Continuing to accumulate parts and assemble / take things apart.
    Slowly making progress. Sometimes...
  1. Ideas on adding rigidity to an 80x160 extruded aluminum gantry
    By DiveN4Gold in forum DIY CNC Router Table Machines
    Last Post: 01-28-2021, 04:53 PM
  2. Aluminium Extruded CNC Router--- X Gantry slippy!!!
    By NobelO in forum DIY CNC Router Table Machines
    Last Post: 07-14-2016, 12:17 AM
  3. please help!!! tslot cutter for 7/16 tslot nut
    By Machinaria in forum MetalWork Discussion
    Last Post: 04-16-2014, 02:17 AM
  4. Need advice/sources for make or buy X-Y table/gantry
    By cnczoner in forum Linear and Rotary Motion
    Last Post: 06-12-2009, 05:53 PM
  5. Gantry component sources & pointers
    By PlasmaGuy in forum Linear and Rotary Motion
    Last Post: 01-29-2006, 02:09 PM
