586,608 active members*
3,628 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > How do I place the FANUC lathe to program X in radius?
    Sep 2016
    What is the CODE that passes X to program in Radius, and not in Diameter? do I place the FANUC lathe to program X in radius?
    What is the CODE that passes X to program in Radius, and not in Diameter? is the CODE that passes X to program in Radius, and not in Diameter?
    Sep 2016
    Re: How do I place the FANUC lathe to program X in radius?
    Aug 2019
    145
    Quote Originally Posted by alexandrebox73 View Post
    [FONT="]How do I place the FANUC lathe to program X in radius?[/FONT]
    It will depend on what version control you have. Older controls require several parameters to be changed where the new controls use a single parameter.
    Provide the control type and someone will most likely provide the settings.
    There may also be macro programs that need to be updated depending on the structure of your machine.
    Also. Please check your settings. Your text is white so it doesn't show.
    Aug 2011
    252
    TRY HERE
