586,119 active members*
3,607 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Central Lubrification - Ways and Ball-Screw?
Results 1 to 9 of 9
    Mar 2023
    7
    I've been working on my retrofitted BF20 (G0704 "clone").
    Aside from replacing the open loop steppers with Clearpath SDSK integrated servos (hopefully delivery later this week) because I got annoyed by missed steps and such stuff...
    I'm also wanting to install a central lubrification system
    What I'm slightly "confused" about are the ball-screws...
    I've installed central lube systems on different machines so far that needed some type of way-oil ....
    But the ball screws I have are greased (by a grease nipple / zerk fitting),...
    Can the ball screws be lubed with the same kind of oil that's used on the machine ways instead?
    My experience with ball-screws is a tad limited.
    from what I know - grease would offer longer maintenance intervals for the ball-screws,... but that would be a bit of a moot point, considering a central lubrification system would be activated at regular intervals anyhow...
    Last but not least: Cutting oil-grooves in the ways...
    I have a larger milling machine (conventional) and would thus have no problem milling nice oil grooves into the ways of the BF20... but on a small-ish machine such as the BF20, is it even necessary compared to a single-point of entry for the oil...?
    Oct 2013
    543
    Re: Central Lubrification - Ways and Ball-Screw?
    My two cents...we did a similar build on a G0704 (CNC) utilizing ball screws, but dumped the X and Z axis ways in favor of linear rails, and added one shot lube to the remaining Y axis as well as the ball screws. The same way lube was used for the ways and ball screws.
    What we did wrong was to slot the way surfaces for oiling in a parallel fashion, when the proper method would have been canted/slanted so there was a 'wiping' action as the two surfaces slid. This method would tend to move the lube cushion over the entire surface of the ways. If you look at any commercially built machine tool you'll see that's how they machine the lube slots. Our thread has pictures that show how this was achieved.
    Stuart
    "THE GRIZZ" photo album - https://goo.gl/photos/yLLp61jooprtYzFK7
    Youtube - https://www.youtube.com/channel/UCT2lq9obzEnlEu-M56ZzT_A
    Mar 2023
    7
    Quote Originally Posted by atomarc View Post
    Stuart
    Hey Stuart, THANKS A LOT
    this was super helpful
    Interesting on the addition of the linear rails - it's somthing I'm pondering for a future upgrade!...
    you mentioned "our thread" - thanks - I've bookmarked it and will look through it...
    I've got a set of clearpath SDSK servos incoming next week... and a 1kW Servo Spindle to replace the machine's spindle motor (and toss the gearing out)...
    and am still pondering whether to keep my machines quick change SK20 (DIN 2080) Spindle (I had an idea to change the mech. release to pneumatic and then build a carousel ATC for it) or go wild and get a BT30 Spindle + housing an Pneumatic tool changer... the BT has a broader selection of quality tool holders... SK20 is a tad limited in this.
    Daniel
    Jan 2013
    474
    Quote Originally Posted by dgentile View Post
    Ballscrews can be lubed with waylube oil, usually a 46 or 68 weight oil. 10ml flow poppers on each lube point, lube pulse every 30 minutes for 30 seconds should be ok. Monitor pressure achieves 25bar and returns to zero after the 30 seconds on time, to ensure lubrication function. Fit a lube level switch too.
    Mar 2023
    7
    Quote Originally Posted by servtech View Post
    Thanks for the details on the timing & pressure for the auto-oiler...
    One question in regards to this... you mention to set it to 25bar?
    seems quite high... most auto-oilers I've seen operate somewhere between 10 and 19 bars... the one I've got around my shop (leftover from an old project) does 15...
    I guess with a lower (than 25) pressure I would adjust the timing - say pump every 30 minutes, 50 seconds...
    Jan 2013
    474
    Pressure sounds high but remember a 3 axis machine with 4 shoes and a ballscrew per axis will have 15 flow popper valves to open at one time and push oil through. Willy Vogel oil lub systems are fitted to most European and many Japanese machines, all have 25 bar pressure systems. Steel tube from the pump to axis mounted manifolds and plastic to the shoes and ballscrews after the manifold poppers, ie on the low pressure side.
    There may be lower pressure systems, but this is what I am most familiar with.
    Mar 2023
    7
    Good Info... I think I'll set it up with the 15 bar unit I have - and see if / how much Oil I'll get flowing....
    if it ain't doing enough I'll hunt down a 25 bar pump...
    thanks again
    Dec 2012
    390
    Stuart
    What did you use for the linear bearings for lubrication? Did you use grease or did you add them to the oiler system? I'm currently installing linear bearings to both X- and Y-axes on my mill (Z done previously).
    Stig
    Oct 2013
    543
    Quote Originally Posted by Stigoe View Post
    Stig
    We retained the small Zerks on the linear rail cars and grease them regularly or as needed.
    Stuart
  1. Double ball nut worth it for long C7 grade rolled ball screw?
    By salukikev in forum Benchtop Machines
    Last Post: 09-02-2021, 07:48 PM
  2. Play in ball screw with anti backlash ball nuts
    By chesty012003 in forum Linear and Rotary Motion
    Last Post: 08-20-2021, 07:27 AM
  3. Ball nut arbor size for 1605 ball screw
    By kdoney in forum MetalWork Discussion
    Last Post: 04-08-2020, 07:45 AM
  4. what bearing fit with acme screw 1/2 -10(for cheap ball screw)
    By apex in forum Linear and Rotary Motion
    Last Post: 07-27-2007, 05:15 PM
  5. Big Ball Screw & Ball Nut mistake.
    By Jack F in forum Uncategorised MetalWorking Machines
    Last Post: 04-29-2006, 04:53 AM
