586,051 active members*
3,889 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > How to set software limit in VK45II
    Hi!
    I have HITACHI-SEIKI VK45II, SEICOS III, build in 1995. Serial number 47146
    When I move axis in Manual mode near limit switches and during some not accurate moving touch HARD LIMIT SWITCHES.
    Machine stoped.
    How can I set software switched to avoid concern limit switched? I rote manual but did not find how to do this procedure.
    Regards,
    Re: How to set software limit in VK45II
    What is the CNC controller brand of your HITACHI-SEIKI VK45II, SEICOS III?
    If it is Fanuc, you can set parameter No.1320 and No.1321
    If it is Mitsubishi, you can set parameter No. 2013 and No.2014.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    I have SEICOSIII. Spindle is Mitsubishi driver. According axis drivers I do not know.
    I send you photo of my electrical cabinet and screen snapshot with 2013 abd 2014 parameters.
    Parameters 1320 and 1320 I could not find in PARAMETER section.
    Attached Thumbnails Attached Thumbnails IMG_20230419_143023.jpg   IMG_20230419_143120.jpg   IMG_20230419_143234.jpg   IMG_20230419_143255.jpg
    Jun 2023
    4
    I have same machine with seicos control and same problem
    i hit z- stop and then hit z+ stop before i clear the z- alarm and now it is stuck,
    cant clear alarm and it wont move
    so dont do that
    Jun 2023
    4
    I have same machine with same problems and it was the limit switches were sticking, they were all gummed up with old oil/coolant and when they were triggered the didnt return to off position. i removed some of them and used a damp cloth with hot water to clean them and then some wd40 to get them worki g again. To free the z axis you need to remove the panel on right side and remove the limit switch, then you can clear the alarm and move it to the top, clean the switch and get it moving freely before putting it back together.
    If you rrmove the lid of the z switch you will see where oil/coolant gets trapped in the cover, i modified it somehow by fileing a small v grove in the lid to let it drain. There is also a water serperater filter doda in the breather hole of the switch which needs to be cleaned too, you should see it bubbling when you work the switches in and out
  1. I need help with limit switch set up
    By Rene Nuñez Paz in forum Mach Software (ArtSoft software)
    Last Post: 10-20-2020, 10:35 PM
  2. Newbie Question about CNC Software | Post Processor | Limit Switch Set Up | First Run
    By arcadiax in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-22-2016, 09:49 PM
  3. ADMIN SET PREVIEW LIMIT
    By tbev in forum Tormach Personal CNC Mill
    Last Post: 07-05-2016, 04:05 PM
  4. Best way to set up home and limit switches
    By brian257 in forum Mach Software (ArtSoft software)
    Last Post: 05-10-2014, 09:57 PM
  5. Replies: 1
    Last Post: 11-22-2013, 11:35 PM
