586,072 active members*
4,578 visitors online*
    Mar 2021
    Siemens SINUMERIC 810D transfer data problem
    We have machine DECEL MAHO DMC 103 V and I have a problem when transferring the program to the machine, attached are the pictures that tell if I set it right, but I just couldn't transfer it, maybe someone knows what i need to do?
    Attached Files Attached Files
    Sep 2009
    99
    Re: Siemens SINUMERIC 810D transfer data problem
    You can connect the machine via ethernet. we have our 810D machines with PCU20 all connected via ethernet which is much easier to manage than RS232.
    Only drawback- you need a Windows XP system available for this, and the 810D doesn't support dynamic IP addresses. (or they do but we have not been able to manage configuring them with Dynamic IP)
    The procedure for network connection is as attached.
    Best regards
    Jaideep
    I have problem with connect dmu 50 ecoline on ethernet..this is siemens 840..can you send me maybe procedure for network connection..
    Thanks more..
    Sinisa
  1. Siemens 810d data transfer interface
    By MikeE25 in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 01-13-2022, 06:42 PM
  2. Siemens CNC 810D Tool Turret Problem
    By kmarsus in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 04-12-2016, 07:43 PM
  3. shopmill siemens transfer data from pc
    By energy84 in forum CNC Machine Related Electronics
    Last Post: 12-24-2014, 08:24 PM
  4. DMG 310 eco SIEMENS 810D problem
    By angelugo in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 06-20-2012, 07:18 PM
