586,108 active members*
3,027 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > How Would you Cut a 12”OD Dial Ring?
Results 1 to 5 of 5
    May 2009
    1332
    The attached shows a 12”OD dial ring for a clock 1.25” wide to be cut on 3/4" plywood. I’m not an experienced cnc user and I wonder if a contour path will do the job or perhaps a contour for the outside and perhaps a pocket for the interior?
    Any suggestions will be appreciated
    Nicolas
    Nov 2014
    724
    Re: How Would you Cut a 12”OD Dial Ring?
    That should work but don't expect the inside corners to be any sharper than the radius of the bit you choose.
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
    May 2009
    1332
    Thanks David for your time,
    Which one should work? contour path or contour for the outside and pocket for the interior?
    I understand about the bit radius, I plan to stop the cut well before and finish by hand
    Nicolas
    Nov 2014
    724
    I most often cut outside the line but it depends on how you draw your model. You'll get basically the same results either way except 'on' or 'inside' the line will produce a smaller part than outside the line.
    David
    Romans 3:23
    May 2023
    May you look for bladers which will help for special corners and etc...
  1. Replies: 0
    Last Post: 07-23-2021, 02:44 PM
  2. Replies: 23
    Last Post: 12-13-2017, 09:29 PM
  3. Draw Ratio of Ring Die in Ring Die Pellet Machine
    By petal123 in forum Other Manufacturing Processes
    Last Post: 08-24-2016, 04:15 AM
  4. O-ring vacuum table to cut through material?
    By CaptainVee in forum Work Fixtures / Hold-Down Solutions
    Last Post: 09-08-2012, 01:30 PM
  5. I can use a drum dial as a dial indicator can't I?
    By slashmaster in forum Benchtop Machines
    Last Post: 11-03-2010, 06:10 AM
