Re: Advice needed for parts selection for new DIY CNC Mill
Ball screws - I don't think our machines approach buckling load (unless you are way undersizing the screws), and don't think you need to calculate that really.
Critical speed / whip speed matters. Very dependent on length
There are easy calculators for this.
Then there is a max rpm related to the speed of the balls.
Often termed DN or Dm.N. Diameter of screw times RPM = Dm.N value. Need to keep this below manufacturer value, often 50,000 or 70,000. 20mm screw times 3000rpm = 60,000.
So there is sometimes an advantage to smaller screws for Dm.N value.
Larger screws are stiffer
A lot depends on rpm you will be driving screw at, which depends on steppers / servos, direct vs reduction (belt/gear) drive etc etc
Rotational inertia becomes a big issue with larger screws. At 30mm and above, screw rotational inertia dominates (much more than inertia of moving parts). At 25mm screws and below, rotational inertia is less of an issue. Depends on relative mass / inertia of moving parts and screws of course
