586,094 active members*
3,844 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma cpu bus alarm 1-1
    Nov 2022
    18
    My mcv4020 w/ osp u10M started having issues booting up, I’d turn it on and off once or twice and it would work, then I started getting the cpu bus alarm, I pulled the board out and the ram cards and reinstalled everything, but now if I try to reinstall software I’m getting the bus alarm, followed with a lot of codes. I got an sc ram card off eBay and swapped it, but still the same thing. I’m having a tough time getting Morris south to look at it, but I need it running.
    Jan 2013
    474
    Quote Originally Posted by Cris_co View Post
    Could be the card rack, pull out everything one by one and inspect the terminals on the card and rack for corrosion or damage, reseat each card several times to wipe contacts clean.
    Then try powering on again and reload data.
    Nov 2022
    18
    Quote Originally Posted by servtech View Post
    When you say card rack do you mean the whole row of big boards? I pulled all 3 ram cards off and reseated them
  1. CPU alarm 1-1 bus error
    By EPTech in forum Okuma
    Last Post: 01-14-2023, 06:24 PM
  2. Replies: 2
    Last Post: 01-14-2023, 06:02 PM
  3. Okuma LB 15 bus error cpu 89
    By Mazzo94 in forum Okuma
    Last Post: 07-09-2021, 10:03 AM
  4. 1-1 cpu-alarm bus failure (cycle out)
    By piston_90 in forum Okuma
    Last Post: 11-15-2017, 03:42 PM
  5. OKUMA SVP board: 1-1 CPU Alarm bus error
    By robodo in forum Okuma
    Last Post: 11-13-2017, 10:32 AM
