586,103 active members*
3,373 visitors online*
    Aug 2011
    154
    4x6 horizontal band saw blade guides
    I have a Harbour Freight 4x6 horizontal band saw with a broken blade guide. The piece that holds the bearings split. I have not been able to find a replacement. Grizzly has them on their website but they have been on backorder for years as far as I can tell. Other google searches bring up mostly woodworking versions or much larger metal working parts.
    I would rather not spend the time making them if I can help it. It's a $15 part on grizzly not counting new bearings. Any other place I can look?
    Thank you.
    Tom
    Aug 2011
    154
    Re: 4x6 horizontal band saw blade guides
    I bought a bunch of stuff from Grizzly to fix the saw guides. Unfortunately the cam bolts were not in stock and the old and new parts have different sized bearings.
    I can't imagine why this machined does not have some sort of after market parts for this.
    Jun 2005
    1730
    You can find cam bolts on the McMaster Carr website, they run about $11 to $15 depending on the size required.
    You could also look on ebay someone might have the broken part you need.
  1. Foundry band saw blade
    By surfside in forum MetalWork Discussion
    Last Post: 03-11-2013, 07:21 PM
  2. band saw blade tpi ?
    By SSN Vet in forum Benchtop Machines
    Last Post: 07-04-2010, 09:51 PM
  3. Harbor Freight 4x6 band saw on sale?
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 02-08-2010, 07:51 PM
  4. Band Saw Blade Inquiry
    By JWB_Machining in forum Uncategorised MetalWorking Machines
    Last Post: 11-08-2008, 07:20 PM
  5. Band Saw Blade TPI?
    By JWB_Machining in forum MetalWork Discussion
    Last Post: 10-30-2008, 01:43 PM
