586,058 active members*
4,698 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > CNC Plasma / Oxy Fuel Cutting Machines > Production says oxy is scarring thick plate after transitioning
    I am a CAD designer and not super well versed in CNC terminology. The production team tells me that when burning thick plate [3" +]when the torch leaves one plate and goes to start another burn, the torch will leave a scar in its path that they later have to fill in with weld. I am hoping to find more info on where to begin to fix this issue. What should i be looking for on the software end to prevent this? We use Pro-nest to create cnc files and the machine uses ESAB Vision 5. I am hoping someone can further school me on the terminology used to search the manuals/settings.
    THANKS!!
    Aug 2010
    19
    Re: Production says oxy is scarring thick plate after transitioning
    A few pix are worth allot.
    show us a screen shot of the nest, and then a pix of the actual cutting damage.
  1. Oxy cutting Armor 2.375" thick Class 1 spec 12560
    By u2tree in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 04-18-2014, 05:56 PM
  2. Oxy fuel cutting lead-in and out advice on 300mm plate
    By Argonian in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 09-07-2013, 01:51 PM
  3. Question about oxy-fuel in moderately heavy plate
    By Steel Burner in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 06-16-2011, 03:39 AM
  4. Plate Beveling round holes? Plasma or Oxy/fuel
    By WSS in forum Waterjet General Topics
    Last Post: 01-07-2011, 07:55 AM
  5. Plasma-OXY-Marker- Production Dream Machine Recomendatons
    By Ben Hagler in forum Waterjet General Topics
    Last Post: 10-10-2005, 02:30 AM
