586,119 active members*
3,605 visitors online*
IndustryArena Forum > Mechanical Engineering > T-Slot CNC building > Advice needed for large format 45x90mm T-Slot build
Results 1 to 1 of 1
    Hello all,
    I'm looking to design and build a large format CNC router using 45x90mm T-Slot extrusions that will be used for light work (mostly MDF and softwood).
    If possible I would like to have the size be at least 3x2 meters to be able to fit a full size MDF sheet.
    I already own a WorkBee Z1+ that's 1500x1500mm, but I have in possession full length 6 meter long 45x90mm T-Slot extrusions, and would like to build something larger as space is not an issue.
    For the linear motion I was thinking on using T5 20mm wide openloop belt.
    My question is about the rail system. Can I get away with using Nylon wheels similar to the ones linked below or do I need a proper round rail shaft with linear bearings? I understand that the accuracy of such system is poor, but is it worth trying or it's a bust?
    https://www.aluminium-profile.co.uk/...heel-kjn218940
    The T-Slot profile I have is attached below.
    If anyone has references or experience with something similar please share.
    Thank you.
  1. Starting New Build CNC, Advice needed
    By broker360 in forum Australia, New Zealand Club House
    Last Post: 04-03-2019, 11:23 AM
  2. Build your own large format printer?
    By rackbox in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 09-22-2016, 06:25 PM
  3. Advice and help needed for large format mill with gantry
    By cnccnc222 in forum Uncategorised MetalWorking Machines
    Last Post: 03-07-2014, 06:44 PM
  4. All 45x90mm aluminum build
    By tommylight in forum DIY CNC Router Table Machines
    Last Post: 05-14-2011, 12:23 AM
