586,075 active members*
3,678 visitors online*
Results 1 to 1 of 1
    Jun 2015
    Exclamation Macro with safety controls
    Hi, i have a DIY 3 Axis CNC with a Csmio ethernet controller + Mach3.
    And now i mounted an ATC (rattmotor 1,8Kw). I have a basic tool change M6 with a M6 T0 for return the tool to the tool rack when finish.
    My Spindle have two sensors for see if i have a tool inside the spindle or if the collet of the spindle are opened.
    I tried various days to modify the code for:
    Read this inputs for avoid crashing one tool-holder to another in the tool rack if i have a tool inside tool holder and mach3 thinks i don't have a tool inside (if made a manual tool change with a physical button i have in the machine).
    Read if the collet open (maybe i turned off the air compressor and the tool doesn't drop to tool-rack or doesn't take it).
    Anyone can help me to understand my errors?
    Thanks to all for your help! i really apreciate any help, when i finish the codes i go to share all versions (Basic version without sensors, basic without sensors but a pneumatic tool rack and one with all sensors for ppl with same spindle and tool rack retractable with "air").
    Attached Files Attached Files
