586,640 active members*
2,802 visitors online*
    Coolant Foaming
    2000 Haas VF0.
    Been using Trim Microsol 585xt for a few months now with no issues. The other day I took out the coolant sump and cleaned chips out of it, and topped off my coolant (running a 9% solution). Ever since this maintenance, i'm getting really bad foaming with the coolant, and it overflows at the return to the chip tray. Any ideas what I screwed up here? Scratching my head on this one
    Thanks yall
    Aug 2015
    108
    Re: Coolant Foaming
    You can try lowering the percentage. Usually the higher the percentage the more it wants to foam but they also sell anti-foaming additives. What material do you cut?
    Re: Coolant Foaming
    Did you disconnect and reconnect any plumbing? Could have an intake leak.
    Re: Coolant Foaming
    Water hardness/softness can play a large roll on how much a coolant will foam , the softer it is the higher the chances are of having foam .
    Some brands of coolant are bad for this and as mentioned there are anti-foam additives specifically made for this sort of problem . I've used an anti-foam which is made for hot tubs and it worked fine . The problem with additives is the need to keep up on them and it's more of a bandage to the problem .
    it shows 4-10% ratio for that coolant so your on the high side . I'd drop it to 5 or 6% and see how it goes . You don't need a high concentrate unless your doing nasty work or a lot of deep tapping in steel
  1. Coolant foaming problem
    By Larry Myers in forum Sharp CNC
    Last Post: 01-26-2016, 09:55 PM
  2. Oil foaming.
    By BlackMoon in forum Charter Oak Automation Support Forum
    Last Post: 11-17-2009, 01:30 AM
  3. VMC FOAMING
    By BAD DOG in forum Daewoo/Doosan
    Last Post: 05-31-2008, 02:32 PM
