586,076 active members*
3,983 visitors online*
Results 1 to 2 of 2
    Oct 2005
    17
    Powerpath 15 x axis servo
    Has anyone replaced the x axis servo on the powerpath 15? The motor does not want to slip out. Not sure if the coupler needs to be loosened first.
    Oct 2005
    17
    Re: Powerpath 15 x axis servo
    Loosen the four lower bolts in the coupler. Drive the wedge out with a chisel in the space between wedge and main body. Motor comes out with coupler attached. Loosen the four upper wedge bolts to remove from the coupler from motor shaft.
    Install coupler on new motor and install in the ball screw mount. No key. Tighten wedge bolts to just this side of braking point.
    Of course, the motor/encoder was not the problem.
    Attachment 492498
    Attachment 492500
    Attachment 492502
    Attachment 492504
  1. Powerpath 15 threading problem
    By joatace in forum Bridgeport / Romi Lathes
    Last Post: 02-03-2023, 01:33 PM
  2. I need maintenance manuals for my Powerpath 15
    By Interact77 in forum Bridgeport / Romi Lathes
    Last Post: 12-28-2011, 01:15 AM
  3. Bridgeport Powerpath X axis problem
    By amgearinc in forum Bridgeport / Romi Lathes
    Last Post: 06-06-2011, 04:56 PM
  4. Bridgeport powerpath 15
    By Nadda` in forum Bridgeport / Hardinge Mills
    Last Post: 01-06-2010, 06:22 PM
