586,453 active members*
2,865 visitors online*
Results 1 to 9 of 9
    Mach4 Need rev 4612
    I am really surprised by Mach4 support.
    I am having an interaction /communication problem between Mach4 and the ESS. It randomly locks up and I have to restart Mach4.
    Mach4 support recommend using the version of Mach4 that is suggested by Warp9's ESS smooth steeper. That makes sense.
    Recommended is the .4612 version.
    Going to Mach4 support, the only version available is .5000 which Tec support stated is "broken and updated".
    If updated, it ought to be a different release version.
    Also tec support stated that no older versions of Mach4 were available.
    I have never seen a software company that not carefully keeps previous versions archived.
    Usually Mach tech support is excellent so I do not know what happened.
    That brings back the question: Where can I download the .4612 version?
    Bertho
    Nov 2013
    4410
    Re: Mach4 Need rev 4612
    I use 4612 and have done for quite a while, maybe as long as a year. It is still available on the New Fangled Solution FTP server.
    Mach4Hobby build 5000 has certain sections of code that now run blazing fast, much faster than they did in prior builds. As a consequence many
    of the motion board plugins were undone by thta extra speed. The ESS was amongst them . What was happening is the fast code set up a 'race condition'.
    Many of the motion board manufacturers have had to update/rework their plugins. I cannot say where Warp9TD (ESS manufacturer) is in that process.
    Craig
    Attached Thumbnails Attached Thumbnails NFSpage.jpg   NFSFTPpage.jpg   FTPpage.jpg
    Thank you Craig for a detailed reply with explanations.
    I missed the FTP server, I kept going directly to the Mach4 section. I am surprised tech support did not point it out when I asked.
    Unfortunately, I am still out of luck: the first version available is 4162, the next one is 4902..
    Bertho
    Nov 2013
    4410
    I think any build prior to 5000 will be adequate.
    In most cases Mach changes very little between builds. I hold to the idea that if I have a build which is working well for me; then why bother updating?
    I found about a year ago my machine was still running a 38xx?? build and had been for three years. I did update to 4612, and I've been using it ever since,
    maybe a year or so. Unless there is something you need or want in the latest build then don't bother. In most cases its seamless but it can and does screw
    up sometimes to.
    I have machining work to do...keeping up with the latest build of mach does not help me get it done.
    Craig
    Nov 2013
    4410
    HI,
    I still have a copy of 4612, but its 100MB, not quite sure how to post it. Maybe send me a PM and I can send it as an email???
    Craig
    Thanks!!
    I have a method for transfer but lets wait a little bit. I sent in a support request to Warp(td to see which version they currently suggest for Mach4..
    I have recently switched from Mach3 to 4. The Mach4 .5000 works fine with the same ESS driving my laser. I am using the same hardware, just moving the ESS outputs between the two machines.
    Bertho
    I finally found out the current recommended versions:
    ESS: v285
    Mach4: .4809
    That brings me back to the same point. The Mach4 FTP server does not have the 4809 either
    So now I am hunting for the 4809 versio9.
    Jun 2010
    27
    there is a link on the Warp9 website for both recommended Mach4 and ESS;
    https://www.warp9td.com/index.php/ge...nstallMachFour
    Thank you so much!
    There is an amazing amount of information on the Warp9 website.
    Unfortunately, I missed those links.
    Thanks again,
    Bertho
  1. Replies: 2
    Last Post: 05-10-2019, 07:32 PM
  2. Mach4 Help Needed: Potentially Paid Mach4 & CNC Consulting
    By rappinadam in forum Mach Software (ArtSoft software)
    Last Post: 11-26-2018, 06:49 PM
  3. PMDX 122 Rev D
    By b'nb in forum Controller Cards
    Last Post: 01-27-2015, 05:09 PM
  4. Steps per rev?
    By Bradosb in forum Open Source CNC Machine Designs
    Last Post: 09-08-2011, 01:37 AM
  5. Mach3 Rev 3.04 VS Rev 1.84
    By Mike 1948 in forum DynaCNC
    Last Post: 02-22-2010, 09:00 PM
